Rota 16" 8j ET20 in Satria GTI?? can it be done?
XlimShady
283
19
i've heard about this place before.. quite well known, never been there yet, not too familiar with USJ area.. i'll try check it out when i got free time
I went there last week. Rm60 to roll per side. In the end i didn;t do it.... coz the fella quite honest. he said my fender the tyre shop already ketuk until almost maximum, so no need to do already.
Is in USJ 7.....google map also shows the place.....
iswara204
545
13
Guys, thx for the input and discussion guys. Honestly, i dont want to roll the fenders! my predictions, maybe the front wheels can clear the fenders. My concerns are the rear! Im gonna try some fitting, will keep this thread posted how that turned out!
Bro, XlimShady and Maze, post your cars pic here bro. Just some sharing.
PocketRocket
'(00) Mod'er
11,164
953
Up Yours
SHANKAR! you notty boi! Just got the car and now modifying it so much huh...think about maintaining your dog as well. xD...
depends on rim design.....some may not clear your rear brake caliper (if yours was drum type then no worries)
but et20 rim definately u need to roll the fender a bit....
here is mine (15" rim et20) that even after i add 17mm spacer i still need to grind the edge of my rear caliper after replacing the brake pads (new pads was thick hence the slim space)
iswara204
545
13
Updates: the front wheels cleared but not the rear..it was scraping the inside the sgti fender liner. It was scraping during corners and also on even road as well :(
Bro maze: I don't want to cut the fender lining arch. Sayang la bro..any other options your looking into?
This is how I look at it, I'm into tackling corners. After doing what ever it takes to get rid the wheel contacting the fenders, will I face more issues going into corners quick? If I have to sacrifice comfort and compromising hard corners, I'll change the rims back to non rota. 7j wheel with appropriate offset!
try set rear camber for -ve2.0degree :listen:
PocketRocket
'(00) Mod'er
11,164
953
Up Yours
I reckoned try 1.5 first, the if clears... He doesnt have to do any shaving
iswara204
545
13
Yeah bro, I'm gonna try -1.5 first. But guys, I just realize, my left wheel is more out compare to the right wheel. Could this be camber issue?
From the pic, the tyres sitting outside of fender already. Tyres I can see the scrubbing on the outer pattern and not sidewall, As mention offset 35 with rolled fender just nice, offset 20 pretty far out.
Maybe can try -ve 2 degree camber, but will kill inner side of the tyres quite fast...
---------- Post added at 11:51 AM ---------- 6 hour anti-bump limit - Previous post was at 11:47 AM ----------
Left side maybe -ve 2 degree also won't help.
Probably not centralized, seen maybe cars like that....:banghead:
iswara204
545
13
Hi Guys, i changed my rims to RPF1 16"' 7j with et40. Fits perfectly! Thanks for all the inputs guys!
XlimShady
283
19
Looks like you have the same probles as me. Front no prob, rear scrape. My case even sadder, there is a screw at the back fender.... the head popping out, pentagon shape head. Scratched my new tyres quite badly on the right side. But after remove the screw then ok. I rolled my fender even more using a baseball bat. Will post pics later.
---------- Post added at 03:27 PM ---------- 6 hour anti-bump limit - Previous post was at 03:01 PM ----------
Have to remove the fender cover before rolling it. As you can see, you will have to sacrifice your baseball bat. It is recommended to use wooden one instead of steel because it will not damage your fender if you apply too much pressure. The wooden bat will crack first if you do so. You can use your hand to slowly roll or you can ask someone to drive the car for you. I did it with my hands, got some blisters. Can search youtube to get an idea how its done.
XlimShady
283
19
wah...can roll fenders using only a baseball bat? any difference ah?
Erm, before this the tyre shop help me ketuk about 50% already. But its not smooth if you ketuk only. So i used the baseball bat to smoothen it + roll it further. Now about 95% in.
I feel that the neo fender damn hard tho.... other car looks softer.
XlimShady
283
19
No heat gun. The pain inside the fender will crack due to the friction. But outside perfectly fine. Even if it cracks it still doest matter coz got the fender cover. But some OCD ppl may not like. Haha
Hello everyone ! This is Ahmed and I am new to the forum. I am student in Malaysia and my Hometown is Karachi, Pakistan. I am into car mods since two years in my country. I am a big fan of Mitsubishi modifications. My last project was Mitsubishi Lancer 4G13 from factory and I turbocharged it. Here are the complete details of the project.
* Stock Internals
* 1.2MM metal head gaskit.
* Nissan Dual Ball Bearing Turbo
* Custom Made Manifold and Piping. (We don't have Mitsubishi 4G13 piping...
