Lightweight wheel nuts worth it or not?
Nope. What for? You're not driving a racing car and a couple of grams weight savings is pointless.
True story : Got one friend using alu nuts (lightweight) and went track, the lugs popped out or loosened and the whole wheel popped out in a corner. No point la.
cvkit17
2,884
1,354
As I always said, losing weight from ownself first is the best solution to make ur car goes faster and save fuel. Benefit to ourselves and our pocket :biggrin:
Like Izso mentioned, no point losing a couple of grams, or even maybe up to 3kg, if our tummy weighs 5 kg :rofl:
Supra_Fanatics
20,673
3,998
The nuts don't even weight 2kg I think :rofl:
Is not that heavy, might as well lose own body weight like cvkit said or just remove the spare tyre :rofl:
mADmAN
1,840
547
the only reason to get them is bling bling..unless u go for proper expensive ones like TPi which can even take air guns.
otherwise... steel is the way to go.
btw... anyone seen any BLACK STEEL lug nuts? prefer open ended... closest thing i could find is the Project U fakies..
Supra_Fanatics
20,673
3,998
Not sure what is open ended lugs but mine are security lugs which is black in colour. :biggrin:
Not expensive less than RM100 for 16pcs
mADmAN
1,840
547
open ended meaning the end of the lugs are not closed.. holes on both ends of the lug nut....so that the wheel studs can go through if ur using extended wheel studs.
mana beli ur security lugs and picture?
Supra_Fanatics
20,673
3,998
Will take photo, buy from Hup Shun Tyres at Sunway.
Not 100% black but something like very dark brown. Will post in awhile.
Security lugs also not to be exact, just different lugs that can't open like normal or without
the key.
Was wondering, if i need to replace tyres if pancit or anything, how am I gonna remove it? :hmmmm2:
the key.
He did not give you the key?
---------- Post added at 02:46 PM ---------- 6 hour anti-bump limit - Previous post was at 02:43 PM ----------
I am using open end lug nuts as my rims have center cover....:driver:
Supra_Fanatics
20,673
3,998
im using RAYS taiwan....rm40 for 16 pcs....lasted more than 2 years till today...
That's dirt cheap bro.
Close end ones if not wrong since I dont see any opening at the end. He did give me the key but
how to open with the normal lug wrench?
Usually they will ask what tools you use. If normal tools from the car they will recommend you get the cross (X) ones and that have 4 sizes. Normal is 19 and 21 and the cross have 17, 19, 21 and 23 which covers both.
If original tools don't fit, puncture time you chialat loh,.....
Supra_Fanatics
20,673
3,998
Guess I bought the wrong ones and he didnt tell me anything about that :banghead:
Will post photos maybe later. My key is long one.
N/A secret
132
7
Kota Kinabalu
hahaha yeah i thought so bro...thanks for the true story hahahahaha:rofl:
---------- Post added at 12:32 AM ---------- 6 hour anti-bump limit - Previous post was at 12:30 AM ----------
hahahahahahahahahahahha speechless bro, so true.
---------- Post added at 12:36 AM ---------- 6 hour anti-bump limit - Previous post was at 12:32 AM ----------
yes, bling2 purposes can la hahahah..:biggrin:
Made the following mods on my ATR....
- Apexi N1 Evolution exhaust (gives a nice rumble).
- Defi boost gauge
- SARD fuel regulator
This coming Saturday, I will be installing the Blitz i-color boost controller.
Ok, having installed the N1 I believe I have lost a bit of low end making city driving a bit more difficult as I have lost some back pressure which the auto does not seem to like....I'm hoping the boost controller will help with this as it will allow me to set boost...
