Need Help!! KE70 rear axle
D7zul
2,697
848
Shah Alam
Dear fellow ZTHians,
My KE70 rear axle now got screeching sound..
I've welded it a year ago.. more or less..
now i think sumthing broke inside it..
well.. u know,
raining season = drifting season :biggrin:
any1 know where to repair it?
NEED HELP!!! URGENT!!!
TQ
mouse8899
76
12
508
petaling jaya
1 - drain the axle oil
2 - remove prop shaft, axles, and rear diff
3 - check for any broken gear or teeth on the diff/axles (weld might have broke)
4 - replace any broken gear/weld back broken welding/change the rear diff and weld back
5 - get gasket for your rear diff, if possible paper gasket + gasket seal
*proper tools are needed, and you have to think of a way to refill your oil if you're doing it at home
mine kinda had a whining noise while it's accelerating, not sure if it's the carb or the rear diff
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
If the noise is not too loud, I think you can drain the axle oil, pump in Castrol 140W axle oil plus Morey Oil Stabiliser on ratio 60:40,
Probably this should reduce the noise level...if not eliminate the noise....
D7zul
2,697
848
Shah Alam
thanx guys.. but i think this is something i'd prefer an experience mechanic to do..
i found a mechanic in klang.. will drive my sick car there..
unless any1 know a good mech in s.alam
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
You gonna drive straight there or going by sideway syndrome?
hahaha....
Yesterday nite (Saturday nite) got heavy drifting at the USJ Go Kart Circuit...
Was there for a short while, my pulse pumping very fast, and heavy rubber burning smell....
Very exciting, its free to watch, were you there ?:burnout:
D7zul
2,697
848
Shah Alam
hahaha.. sideway confirm cannot get there.
but wierdly, my axle didn't hv that sound anymore this morning..
anyhow.. i just let d mech open it up to check..
better be safe than sorry, right?
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
Most likely its the rear axle oil...
When its hot, it loses its viscosity thus you hear that sound,
When its cold it lubricates again...
BTW i saw your KE70 in the Album section, its 1981 made right?
Its after the DX model right? Before the BBB model right? :confused:
D7zul
2,697
848
Shah Alam
yup.. probably the oil too..
saw them took it apart yesterday at workshop..
oil very black.. then change both bearing..
now ok la.. heard a very soft screeching sound.. dunno if it's the sound of the 'locked' axle or what :biggrin:
will try it first.. hope nothing blow out when i go sideways :wink:
:driver:
---------- Post added at 12:52 PM ---------- 6 hour anti-bump limit - Previous post was at 12:51 PM ----------
oh.. mine is black belt DX model..
most people call it that.. :biggrin:
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
:driver:
OIC, means yours is the Black Big Bumper model...(BBB)
Drifting is an expensive hobby, so i think you are prepared for it!:driver:
D7zul
2,697
848
Shah Alam
not black big bumper.. my bumper mostly metal.. its like this
A Post Every 5 Mins
Guys,
Recently, I am facing with this irritating noise whenever I brake.
It sounds like eeeee....
The brake pad is still thick.
Any clue? :hmmmm:
Thanks.
