L200S Need help again...
mouse8899
76
12
508
petaling jaya
I need help from you sifus again....
Ok, since alternator problem was solved this was another one that has been bugging me till I burst my head.
Firstly, when the car was brought in, fuel pressure at the fuel regulator was reading 6 (if not mistaken)
No weird noises on the fuel pump. Then a few weeks later, there was some weird noises on the FP like it's suffocating (something like sucking a hollow end plastic bag with your mouth) and pressure reads 4.
pressure goes up a little when revved, probably near 5. Sometimes on idling will hear it rev a little then stall a while. Stall in just 1 second interval. (Like *vroom* stall *vroom* stall)
Secondly, when I engage the clutch after shifting gears (I mean all the gears 1-5&R) any of these, the car straight away silent mode(even quieter than idling) and no response on the engine even on full throttle. I have to maintain some throttle and the clutch at certain levels to keep it moving (as in slipping the clutch) to move the car. But this didn't last long, probably in 2-3 mins the engine stalls on me.(Felt it was stalling, clutched the engine & let go of throttle) On idling, no problem. But when the gears are engaged, this happens.
First time encountered this kind of problem... no idea how to solve it:confused::confused::confused:
123
2,007
23
aircond on? change ficd to Toyota? did u lighten you flywheel?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Things that I could think off:
  1. Clog somewhere? first by replacing the fuel filter... if not then work your way the fuel lines to check whether its clogging
  2. electricity, your previous post mentioned that you have issue with wiring... could be it affecting the fuel pump. do check its wirings and relay
  3. replace the fuel pump altogether... a hint, wira 1.6 fuel pump bolt right up and could be used up to 200hp if you feeling naughty with the engine :listen:
my guts telling its some gearbox issue... I'm going to my fave pomen this evening, I'll ask him and post his answer here later
paging papagoines.....l2s/l5 expert...
Haiyo! no expert la... just happen to friend some otais and sifus la....
123
2,007
23
firstly, throttle body?
secondly, too much engine oil?
mouse8899
76
12
508
petaling jaya
    ok will check on the fuel lines
    borrowed a new set of wiring from the chop-shop today, fixing it up in process... old wiring many fly here and there on the relay side, even you see also :hmmmm:
    that would be the last resort
ok, thanks... when ever under load it happens. but if jack the buggy up on jack stand, running smooth gao gao
the other day when replacing valve cover rubber seal found the valve train sludge everywhere, mostly hardened sludge on the tappet side, could that lead to this issue?
throttle body inside is clean, don't think it cause this issue. but there is 2 hose fittings under the throttle body that is left open. no idea where it goes to. buggy not using brake/clutch booster, just individual cylinder
engine oil level is ok
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
shown my pomen this thread yesterday... he also no clue
he says need to see it for himself...
as per sludge issue, try clean it up and test again.....
mouse8899
76
12
508
petaling jaya
tried to clean up without taking everything apart... unless have to do full overhaul, just scared after overhaul and still the same result and waste a lot of time. for the time being swap in the wiring and try first
if you got any word on this problem, please give some tips here
DanzEterna
15,911
3,371
www.primeperdanaclub.com
**check for any loose hoses. especially the throttle body hose, check that 1st, then move down to the rest.
**try to shorten your clutch pedal. there is a screw just above your clutch pedal.
Hello All ! Well Im going to get my Laser TX3 soon ( Its an old car lorr , still havent saved enough to buy monster ) . So will be joining zerotohundred as a Ford owner :biggrin:
Btw , of course i want to mod it . Any suggestion where to begin with ? Underhood or exterior ? Or cannot mod liao ? Its a waste or money or what ?
I need Sifus help on modding the engine to make it MORE powerful (im kinda...
