I have been charged check & fix wiring
imkelvin
Oct 13, 2012
I have been charged RM60 for checking and fixing wiring for my Proton Iswara of Power Window Switch. It is reasonable? Can anyone tell me?
DLegend
Official Contributor
430
14
5,018
jayjaynyc.blogspot.com
What was the problem? Sometimes if takes them the whole day to find and solve the issue, RM60 might be ok....
nyantong
192
50
Bro, people also have to eat mah. Plus this is diagnosing and wiring, not replacing brake pads or changing oil.
Did he remove the door panel and all that? But half hour quite fast job.
My friend fitted Double Din player, take old one out and put in new one, accessory shop charge RM40, but for me he charge RM70, but I paid because China car, he had difficult adjusting the depth, so he took much longer time to do.....
ken yeang
6,617
1,327
better ask the technician how much he gonna charging, or at least an estimate, before start working on the car.
Fair and square, for both parties.
i dun think now can easily find rm20-30 labor charge edi, unless mechanic bawah pokok
if rm30 labor, after deduct the shop rental, worker labor etc etc fee....negative profit already
Still have. My mechanic that day check my wiring for air con, charge RM20 only. Initially I thought big problem because suddenly no more cold air and maybe compressor kaput. He check and say compressor not running. Check about 20 minutes found wire to air con in engine compartment broken. Just join back only.....:rolleyes:
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
Come on la Kenny,
Its not only one customer paying RM30 a day...
If only one customer a day, quickly close shop already no need to wait any longer....:listen:
imkelvin
Hello, you are not answering my question. I don't care people have to eat or not. We as a customers also have to eat. So, I am ASKING, not ARGUING.
Come on la Kenny,
I agree with you bro, I felt that it is quite expensive for me as I see I don't feel that it is very complicated.
Hard one, sometimes the technician don't know how deep is the problem and want to go how far is it for the wiring.. but good idea also bro. thanks
myakac
6
508
In my opinion, it's reasonable.wiring troubleshooting become expensive not because the look of how it perform. it look easy but it require essential knowledge to troubleshoot it and some are very hard to solve eventhough it look simple. some knowledge in wiring not come cheap as some earn it in hard way. just my 2 cents...
Hi all,
Today I noticed my RH drive shaft and lower arm has marked like been touching and it quite clear. I wonder what could be cause this? Is there any issue if uses aftermarket abs (Im using aftermarket abs)? Or is there any other different car's drive shaft that been installed from previous owner?
Thanks for the advice in advance!
