GT Radial Champiro HPY
30,002
Hi Guys,
This is the latest tyres I am using. Y rated GT Radial. Fitted them is August.
The grip so far is very encouraging and even in the wet, aquaplaning resistance is pretty good too.
The only cons is I feel they are a bit too hard, so for comfort is not good, however for kakis who likes hard corners will be good.....:driver:
30,002
nice sharing , u did use v12 before right?
V12 almost....ha! ha! Let me see if can remember the tyres used on my VR.....
Kumho RE711
Falken ST115
Yokohama ES100
Dunlop SP9000
GY F1 GS-D3
Falken FK452
Yokohama S-Drive
Toyo T1-R
GY Asymmetric
Blue Streak Stilletto
GY Asy 2
Whoa tried so many already ha! You're like a tire test driver already. Must have been travelling on the road all the time then.
As for your comment about the GT, quite surprising you mentioned it's a bit hard. Cuz normally GT Radials makes tires with a bit softer sidewalls. I've tried them before around 5-6yrs ago and they were quite soft and comfy. Maybe they have changed it now. As for grip, they're pretty decent, I say good value for money.
30,002
These are their latest Y rated UHP tyres.....even unmounted, I try to press sidewall also hard....
g4i8y0t
1,216
330
683
Kedah
This is the same tyre used in Proton Preve. Mr vr2, how about other aspects like noise level and steering feel?
Supra_Fanatics
20,685
3,998
got 16" right? Maybe I'll try next time with my 16". Don't really feel confident with XM2 in corners...
30,002
Is it? I thought they use same one as Proton Exora Bold and if correct that is the GT Radial BAX2.
If they are the HPY, noise level to me is pretty good and steering feel for my VR also good...only bumpy....ha! ha! maybe because of my adjustable too.....
---------- Post added at 09:48 PM ---------- 6 hour anti-bump limit - Previous post was at 09:46 PM ----------
HPY starts at 17", however have Model HPX directional ones in 16"
xenith
36
Mind sharing us the price?
EvolutionZ
5,000 RPM
5,025
1,448
all Preve and Exora are using this tire ...
EvolutionZ
5,000 RPM
5,025
1,448
oic ..paiseh but the grip is also good..i tried out the preve cfe (turbo)...it wont skid easily unless u hardcore it lor
30,002
Model BAX2, should be improved model over the older BAX.
This model under High Performance category. HPY is UHP.....
Preve and Exora this model.....
BAX2
Ah the one I used back then was the BAX, very similar to the one on the picture above.
Yea, the UHP one should be stiffer in general. What's the treadwear and traction rating btw? The price is very competitive.
30,002
Threadwear 300, Traction AA, Temperature A, Load 91, Speed Y
Yup, since it perform pretty well, and at that price is worth it......:driver:
markblurberry
115
20
Bro VR2Turbo, can tell me if can get better price than Rm320 for 215/45/17? My fren is interested in champiro, but compare achilles is cheaper, if can get around RM300 or 280, i think he wish to try GT Radial..please advise whether can nego or possible cheaper in Klang? thanks...
30,002
That is the market price I think. I got them at exactly RM308 in August. You have to check the prices in Klang to see what price they sell at, but a few mentioned difficult to find because not many tyre shops selling.....:hmmmm:
Hmm about the same rating as my F1-D5 at cheaper price. Should've considered this one instead. :( Maybe next change then.
A Post Every 5 Mins
my kancil' l2 temperature rise slowly when switch on the aircond but when turn off the aircond, the temperature decreses slowly, when this problem occur, I have changed new aluminium radiator, new fan,overhaul,flushing,direct power fan,check the wayering and grounding, and hoses but the problem still occur. can someone help and give suggestions?the termostat have been remove,i tried with normal l2 radiator,check the meter,every coolant,added extra fan,changed water pump-all these i have...
