Skimming Disc Brakes..
paohyean
Dear sifus here,
Need some advices from the petrolheads on skimming the brakes..
My Persona has only got about 50k km on the clock..
During 40k, I changed the brake pads because I noticed that my brakes weren't biting enough..
Recently, I noticed lines and grooves on all 4 disc brakes in my car..
My question is..
Is it worth skimming all 4 discs??
And if so any good recommendation in doing it??
Thanks a lot in advance..
Is it already vibrating when braking, especially from higher speeds? If not then can just leave it for now, but if it's already vibrating then can skim a bit.
The weird thing is the brake pads are only 10k old..
And I did notice a lot of grooves and lines on the disc..
Hence the pondering on whether should I skim the discs..
Well the pads do seem to be harder..
As compared to the original pads which gave out dust like nobody's business..
These pads doesn't seem to give out any brake dust at all..
That is where the pros and cons comes......
Well i think if the discs have grooves and lines and if the brakes are still doing perfectly even after 10k then you should be considering to be changing them after a while i mean i changed my rides discs because they were not good at braking and last time it did slipped so i did changed........
Some other things you can do is bleed the brakes again, clean the pads & calipers & readjust the gaps, adjust the handbrake to make it tighter. All these normally may help to make your pedal feel tighter and more sensitive in braking.
A thread every 60 seconds
