chubster
Hi bros can anyone tell me what will fit? Would an evo 4 manifold, turbo and dp bolt it? What models can/cant
evo 4 to 9 is compatible wif treks
so a evo 4 turbo, manifold and downpipe will just bolt up? oil and water lines still match up? or will i need the ones from the evo 4 turbo?
i have a really nice t3 manifold, turbo and downpipe sitting in the garage, i did test fit last night and its a no go, bit bummed really but a guy in my hometown has a evo 4 setup going cheap.
No go? what seem to be the problem with your T3 setup Chubster?
I would try to make it work since U've already got all the major hardware, unless it's a serious compatible or mounting issue. Let me know, see if I can help :)
---------- Post added at 10:22 AM ---------- 6 hour anti-bump limit - Previous post was at 10:17 AM ----------
If not mistaken, the original oil & water lines can be used, but the fittings on TD05 turbo are bigger. Your best bet is to get the Evo 4 turbo with all the fluid lines & fittings attached.
is ur t3 maniold custom made?
thanks avant. yea no go, cant be bothered with the hassel. the t3 turbo sits quite low so a custom intake pipe will be needed, 1 stud hole on the manifold is about 1mm off, so would require some machining, 3" downpipe is just a tad to large and hits the starter motor bracket. because of that the pipe wont sit up high enough. so that would require a custom job there aswell. and im not sure but it looks like the flange is offset by about 30deg to the tubo so the bolts dont line up.
ill be able to sell it for what i got it for so not a major there. i had suspiscions so thats why i did a test fit this weekend. im glad i did really
Hi sorry had to ask. So if I go out and buy a TD05 turbo from a Evo7-9, all the lines and fittings etc, buy a td05 manifold for a evo 7-9 and also get a turbo downpipe, they will all just bolt straight onto my air trek? No need to remachine any of the holes etc? And then tune of course.
My ATR was mod to TD05 setup by previous owner..
from what i know, my ATR are using WRX STI pink injectors..direct fit..
Similar threads | |
