car skid
seviates
Nov 4, 2011
17
Hey guys,
recently, i found my car totally unreliable for cornering
just days ago, i took a simple sharp turn and the cat skid
spun and hit the divider (bumper cracked)
i can understand if i had gone really fast, it was 40-50kmh
on 2nd gear.
I noticed this on highways too.
whenever there is a corner and slight uneven road,
the car is like trying to throw me off and i feel like
the back half of the car is not really holding the ground
i have changed drive shaft,steering rack, suspension mountings, steering bush
one thing i noticed i noticed is when turn the steering full either left or right
and then let go,the steering does not come back to correct position, its like it
something not balanced
using a putra and need you guys advise. I dont feel safe driving that fella right now
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
Hey guys,
on 2nd gear.
What about your absorbers?
Conked absorbers can cause skidding...
Also other items in your suspension system is in bad shape, loose etc...
:burnout:
seviates
17
i changed my tires all 4 of them within the last 6months.
i hardly drive too.
but considering that the ride is already 16yrs old, it could be the case.
just wanted to know if absorbers and spring could be the primary cause
of my problem
i'm thinking its a combo of that plus the steering thingy
ken yeang
6,618
1,327
you drove on oil patch?? There could be some "human made" accident spots....
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
Another cause could be your brake disc are too thin (worn out)
A very thinner than usual brake disc could cause your brake to self-jammed one sided...
If its too thin, i suggest you change the brake disc on both sides, front & back..
---------- Post added at 02:11 AM ---------- 6 hour anti-bump limit - Previous post was at 02:10 AM ----------
If you catch them, give them to the dogs first??:listen:
Supra_Fanatics
20,685
3,998
What tyres are u using? best not use silverstone or sime tyres :rofl:
UR bars as suggested by Danz, I guess that would help.
15,390
There are only a few things that I can think of that causes that sort of skid :
1. Crappy tyres like Bridgestone MY01 tyres. I experienced the same thing as you at 20km/h.
2. You have overly aggressive or incorrectly set toe and camber settings. Usually apparent when driving straight and the car is fidgety.
3. Remove whatever bars you have especially the rear upper room bar. That one causes extremely oversteer-y issues.
4. If your steering isn't turning back, you need a new one. My steering rack died after issue #1.
5. Bent absorbers and/or springs. Dead absorbers and springs will just make your ride dead awful.
6. Dead bushes that change the geometry of your wheels.
7. Overly aggressive brakes that you stomped on mid corner. You shouldn't need to brake in a corner at those speeds.
Supra_Fanatics
20,685
3,998
Tried hard braking once cuz hesitated when reach corner at certain speed :rofl:
Lucky got ABS if not sure skidded :rofl:
15,390
Threshold braking and late braking is different than braking in the corner. It's easier to control an oversteer than an understeer!
ken yeang
6,618
1,327
the whole skidding can be traced from many aspect. From the thread starter, the speed indicated was about 40-50km/hr. However he didnt mention about how tight the corner was.
if taking tight corners, even at 40-50km/hr speed, I wont be surprised if the car can "buang", under the right circumstances...
EvolutionZ
5,000 RPM
5,025
1,448
for putra, u need to check the history of yr car. send to any mudguard panel beater and seek their help to view the car to determine any major accident before this...and send to a good mech to diagnose if there are any wear & tear parts need to change.
maybe after that u know where to tackle yr skidding problem
ken yeang
6,618
1,327
yeah, possibly the chassis sudah not alligned, or "crabbing" liow...
EvolutionZ
5,000 RPM
5,025
1,448
many possibilities, since many of our members have suggested some counter measures, do check on the chassis as well...on the suspension, cross members etc
Supra_Fanatics
20,685
3,998
From what I read, most stock cars especially sedan are designed to understeer rather than oversteer right? I mean from the factory set up?
They said it is because it is easier for a driver to control the car be it experienced or inexperienced
drivers.
There was once I whack a corner by hitting the brakes hard, my car skidded...well that is one wet road though :rofl: and on Silverstone tyres...:biggrin:
Supra_Fanatics
20,685
3,998
Read it somewhere can't remember, it says it is easier to counter steer a car that understeered than designing a car to oversteer like last time...
(Kazukimy, ur car FR ma...surely oversteer easier for u to control...can drift LOL!)
kazukimy
638
372
1,563
KL/Pahang
devil-home.blogspot.com
erm, because of the momentum shift to the front side of the car (usually 60-40 in most car due to the weight of the engine) where the amount of stress on both front tyres were quite immense, hence losing traction and unable to control the 'understeer' angle no matter where u had change the steering due to the force/momentum that still forcing the car to move forward. whereas oversteer where ur rear slip whereas ur front still have somewhat grip to control where the 'head' of the car was heading, hence in my opinion, oversteer is easier to control rather than understeer, since nowadays most car have abs,ebd and vsc...understeer seldom happened unless u went over treshold limit or off the vsc..wakaka...:smokin:
Supra_Fanatics
20,685
3,998
So with VSC on, the possibility of Oversteer is more likely? Never off TRC before...
Swiss tuner Rinspeed has revealed their latest creation based on the Porsche 957 Cayenne. Named the Rinspeed “X-treme,” the tuning package for the facelifted Cayenne gives it a sportier look and more peformance.
Appearance wise, Rinspeed gave the Cayenne a new front skirt and bumper, bigger air intakes, beefy wheel arches, new side and rear skirts and two...
