Brand new F10 BMW deliver with etched water-spots damaged - restored and OPTI COAT pr
kc2
1,354
1,410
thedetailers.blogspot.com
Getting new car always comes with bundle of joy & excitements
My buddy, contacted me to protect his investment a couple of weeks ago prior collecting his brand new car, and we specifically mentioned not to be wash by road side car wash
on his way home driving thru some highway under construction and pilling
splashes of 'Wet' boring* spillage (drilling fluids) splattered the under wheel wells and lower side of the car
drilling fluid systems usually consist components of a kerosene-like
petroleum base density compound.
so pls flush off instantly...to avoid hard to removed mud like stains....with Alien clean
this is not an easy task to remove especially when is left unattended few days but with Alien clean effortlessly
we always begin by a good good washing with Alien No rinse wash + Alien clean
cleaning the electronic damper control carefully
more cleaning with Alien clean
more cleaning required
anti rust drips
spray on brush off & rinse away with OPC
before
after alienised with Alien clean
a weeks old wheels
closer
closer
immerse amount of dust accumulated and not easy to clean but..............................
after a simple bath - with Alien clean
before
after a good bath before opti coat
rims exterior before
after
moving to side steps area...
removing dirt trapped in between by Opti clean
center console cleaning make easier with OPTI Clean
cleaning the fuel filler area
a newly fitted universal Diesel filler adapter cap for all petrol station (as many comes with difference size of pump nozzle)
moving in
to clean the rest with the effortless Optimum Opti clean
example
before
after Opti clean
after a good good bath - we further prepare the paint surface decontamination - follow by inspection as paint need to be carefully studied and measured prior correction
this enable a quick assessment of the quality of the paint finish and to verify the clear coat is not endangered or too much of clear coat being removed during paint leveling / over excessively
we discover some deep water spots etching on the paint
closer
The most important thing a person can do is to find out what caused the problem and then try to avoid it into the future because you cannot continue to compound a thin, hard factory finish as you'll go through the clear and expose the basecoat.
MIKE PHILLIPS
another water spots etch
thank God, we had this came along to study how much clear coat to be leveled when removing the extensive water spot damage.
more at the water trapped at the catchment area of the rear bonnet
In order to remove this kind of crater etchings water spots we have to abrade till the lowest surfaces /depths of the crater etchings, this will remove paint.
before
after polish & paint measure
after coating
point this out because I helped a guy once that got crater etchings from a sprinkler that went off at 4:00am every morning where he parks his car at a Condo and after he removed the spots he continued to park there.
MIKE PHILLIPS
after careful inspection prior opti coat applied
a simple illustration
galaxy
far away
paint re define
another hot hot day
ta da
the most wonderful protection anyone could gives to these chrome parts is opti coat
close up inspection after opti coat
more protection on plastic head lamp
side mirror plastic parts protection
front door
front bonnet
after
wow wow
amazing reflection
look at this
look again
clarity & glossiness retain under opti coat
rear bumper
rear
twin tail pipe polish by Master seech with optimum metal polish
thank you for viewing another detailing thread of KC
the front
the rear
the over all
another sheer driving pleasure ready
ShowTime
88
77
Re: Brand new F10 BMW deliver with etched water-spots damaged - restored and OPTI COA
WOW! Master KC got a new toy! A reputable brand paint thickness gauge!! I want to take READING of my RED! :love:
seech
400
445
1,563
My pics from the F10 detail with KC.
Claying with alien no-rinse as a clay lubricant.
As expected from a new car, very minimal contamination on the surface.
Sifu KC at work cleaning the wheel arches...
while I dealt with the twin exhaust tips.
Cleaning with alien clean....
Followed by Optimum Metal Polish.
Done.... nice and shiny!
Now for the detailed paint inspection.
Hmm.... water spots/etching... seems to be common on our F10's.
Compounding with the latest Optimum MicroFiber Compounding pad with Optimum Hyper Compound pads to remove the water spots/etchings.
Followed by polishing with Optimum Hyper Polish and the Optimum Double-Sided Red Foam followed by the Flex3401 with the Optimum MicroFiber Polishing Pad with Optimum Hyper Polish for the ultimate finish.
KC polishing the front bumper after removing the license plates.
Permanently protecting the paint with Optimum OptiCoat.
All done...
Awesome gloss and shine.
More details to come.... :-)
ShowTime
88
77
Near ZERO DUSTING using Optimum Hyper Polish! Some polishes(creamy/liquid type) I noticed once polished will leave the whole panel covered with polishing dust that requires clean up later but I noticed little to no dusting using OHP. Even KC doesn't require to wear a face mask. :congrats:
DarkAccoon
880
432
3,063
KC, your face arrr..... makes me wanna say
"Why So Serious!" ala Joker style.
kc2
1,354
1,410
there is always a time for everything - u dont do it when u r detailing others car.....
of all the workshops u attended so far- i always have plently of jokes and humour
thats natural me....no when u r battling with this giant issue.....
come lets have some fun now
help, last friday i feel that my car air con is not cold, so sat i send to the workshop for inspection. then the mech say its because the air con gas not enough, so he just refill the gas for me and say ok d. then on the way i driving home, i can feel the cold air, but then got some gas smell when the moment i just on the air on. then today when i drive the car again, the air is no more cold liao.
i was wonder i can smell the air con gas inside the car, mean there is some leakage right?and...
