DIY Honda ECU Repairs- P30 P08 P27
If all caps hv been changed then highly possible the culprit is IC 17.
ok thank you. since we do not have this IC17 here. i was thinking of doing a transistor array.
I have the circuir equivalent of the STA...
its 4 NPN general purpose. i found a transistor that have the same specs. i was thinking to put this 4 transistors together and have the pin assignments the same as the IC17
have anyone tried this.
I use 2x 2SD1415A to replace STA460C before. Direct solder w/o any modification. However, I never have any chance to try this way of replacement on STA413A.
Just FYI, STA413A is 4x high hFE Tr. You can't use any general purpose Tr to replace it. You need a Tr with minimum 500 hFE.
thanks i was not aware that there is a closer part to replace.
how about the TA9803SN
do you know any replacement parts or do you have the datasheet.
cannot locate any of this here.
TA8903SN is a 5V regulator with watch dog timer. There is no direct replacement for this item.
If this IC is fail, you will have permanent engine light turning on, with very irritating idling.
Ryand... Stock of Ic17 arrived today..
If u still need them, pm me.
well engine will not start at all when engine light is on.
@ e-tech pm replied
---------- Post added at 09:47 PM ---------- 6 hour anti-bump limit - Previous post was at 09:41 PM ----------
anyone has a block diagram and pin outs of this TA8903SN
can i use the auto IC to replace the Vtec IC..
is it ok to remove the auto IC and leave slot empty
i converted it to manual anyway
Yes you can take ic15/16 to replace ic13/14. Try 14 first.
sifus, having a problem with my ecu (p30).....the car wont start went cold......if hot it's ok......any advise????.....thanks
These are signs that ecu going bad. Anyway uv a look in the ecu.
The caps maybe leaking already...
a friend gave me an ecu. from what it looks like it was factory with external chip. P70. the extrnal chip. C49 C50 IC etc i know was not done by hand.
the problem is.. some one removed the chip and damaged the board. some one cut J1 using terminals of the SMD resistor was still there
he gave it to me, the ecu start. with 1.2k idle and gas smells bad.. with constant CEL. i did a CEL check, it will not blink?pulse
what i did was replace the caps that have signs of leak and re trace the copper wires to i can place the socket pin (bed) so everything is good since i have a good working ecu beside as a golden sample.
I started it again Idle was a little less than 1k but smoke smells bad and constant CEL, CEL check
do not throw codes constat cel
anyone can help. i suspect it needs the factory external eprom that was remove..
im pretty sure it came out stock with external chip..
question is for a factory ecu with external chip. does the internal Prom still work if J1 was removed.
hi guys! can anybody help? i plan to repair my ecu. i am currently using a p27 manual ecu and there are times when i start the car the main relay ticks twice. and sometimes when i start the engine from cold start RPM drops which makes the check engine light blink again.
BTW all 7 capacitors were changed and changed main relay already
Post a good picture of the board. Let see f I can spot the problem
hi...i willing to repair my ECU, can u please give me the info of where to send and what i should attach together? If can i will send it by end of september or octorber... Could it be modified by re-chip? and i need a quotation for the price...thx...
Bro E-Tech,
I have stock p08.
-I have cleaned TB and IACV. {Still erratic idling (1500 - 1700 RPM) and cel 20/14 code. }
-I have replaced the capacitors (C21, C27, C31, C32, C34, C36, C94) in it. {Still erratic idling (1500 - 1700 RPM) and cel 20/14 code. }
*Idle goes smooth/stable on 1500RPM when replaced with another P08. No more erratic.
What are your suggestions please.
---------- Post added at 09:41 AM ---------- 6 hour anti-bump limit - Previous post was at 07:42 AM ----------
Code 14- iacv
Code 20- eld.
14 needs to solve if not idling up and down.
Check the related transistor to iacv.
20 should not be a problem...
May I know what is the related transistor to iacv?
Keeonn123,
PM send. Pls check.
---------- Post added at 02:31 AM ---------- 6 hour anti-bump limit - Previous post was at 02:30 AM ----------
Bro E-Tech,
I have stock p08.
Toxic,
PM send, pls check.
anyone have rechipped a stock ecu with external chip already. i am sure its stock since solder was very clean and the same with other components. p08-900 auto
question: i remove the chip and place the chip bed then put the chip back.
remove rp17 and jumper rp18
tested and all is ok..
now i place a switch so it can run stock and chip.
tested switch to chip, everything is ok no CEL
tested switch to stock, CEL 19 WTF!
please need inputs thanks
