single throttle vs 4throttle
a3rosp3c
hello everyone. i have been doing some research/comparison between single throttle and 4throttle. this topic might have been discussed before but i really need a very good technical answer from any of u guys who have more experience or have gone thru this kind of modification. my question is which throttle body is the best for high revving car, up to 9000rpm or above??
some people said that single throttle is the best for high revving compare to 4throttle. if it is true, why? In japan, most honda that can rev up to 9k rpm or above is using large single throttle body and this is common there. as for toyota, there is a tuner or shud i say engine builder has developed toyota formula atlantic engine that can rev till 8.5k rpm producing 240HP using 4throttle. there are so many theory i have read n heard so far and its making me confused even more.
what do u guys think??? lets share information
i prefer a larger single tb and a larger intake compared to a 4throttle setup, easier and less fussy imo. its a different story if the engine comes std with an independant throttle system like the 4age 20v, skyline gtr, etc
Its easier to tune a single giant throttle body compared to 4 individual ones.
RB26's, a LOT of them convert to single throttlebodies. But maybe it has something to do with being NA and force inducted also? :hmmmm:
Just my 2 cents.
rev limits does not just depends on throttle body set up... engine setup, rod ratio, borexstroke, fuel mapping, cams, etc. all plays a major role....
dunno y but i prefer 4 throttle, more garang...but dunno bout the pros & cons though. :)
there is reason why most inline4 engine on superbike use 4throttle instead big single.. :biggrin:
well putting engine configuration aside....4throttle have a better advantage over big single throttle....where it combats main weakness of big single throttle:: throttle responds...
especially when u were going into high rpm engine mods which require high flow intake setup....yes big single throttle have high flow....but a properly sized 4throttle can achieve same result....and without lumpyness throttle responds over big single.... :adore:
Hello all, thanks for all your reply. btw thanks pomen GTR for giving me a very good explanation. i was getting confused regarding this issue but once u mentioned 4 throttle with properly sized, that was the answer i was looking for. hehehe. thanks again
i'd say :
single throttle for low to mid rev..
4 throttle for mid to high rev..
gudluck :burnout:
a well designed intake manifold can be as good as individual throttle unit...
true also...
for some reason such as part costs and tuning difficulties, thats why we see some 4g9* modders custom fit skunk2 racing honda intake on mitsu... :biggrin:
but for ultimate setup my choice would be 4throttle any day... :adore:
my 4throttle.. but it just craby
better response & awesome sound
BTW do F1 cars run single thrott or ITB? the answer is there.. ;)
itb need at least pigiback
while bigger single trotle+bigger im still can stand wif oem ecu
actually what car r u using?
most car using single throttle stock.. because they are for daily driving..
performance car using 4 throttle stock.. because they're for daily driving & weekend racing :biggrin:
so, if u want ur daily driving to be a performance car.. just put in 4 throttle & tune it up nicely..
Ever felt a car with twin carbs that are out of sync? 1st gear up a carpark slope heheh :proud:
A thread every 60 seconds
