untouchable
Nissan might have change the original part with local ones, just speculate. They maybe want to reduce the cost, thus cost a lot a problems after that.
Not just the Sylphy but also Sentra & Livina.Nissan is now offering big discounts for the Sylphy. Some dealers in KL offering up to RM 9-10K.
my 3 yr old latio's aircon recently something went wrong, sometimes aircon is cold at first,but after driving awhile,it become not cold at all, left the fan working.then u need the switch off the aircon then switch on again,then it will start functioning,and u can see the foggy gas coming out from the fans there,it become very cold for awhile b4 the problem comes back again!sigh!!!!!what happened?DON’T BUY NISSAN.
I owned a brand new Nissan Sylphy since August 2008. Until 09/04/2010, my car mileages run up to 90,000 km.(Car age: 1 year 7 month).
The quality problems I having so far as below: -
1) Dashboard has bubble spot - changed on January 2010 - problem solved – reason given was Japan and Malaysia weather difference.
2) Complaint on suspension noise - when turning and on uneven road (since 2nd service
mileage 6710 km until 89,994 km). NOW 90,000 km only solve the problem with
changing the caliper set !!!!!! All the while Nissan Malaysia only gives the solution
of "Tighten Undercarriage" for this problem.
3) Gear Oil Leaking - replace gearbox oil seal 2 time but problem still not solve. Now Nissan only agreed to replace a new gear box.
4) Air Con Gas Leaking - replace cooling coil (recently) - problem solved at this moment, later don’t know yet.
5) Everytime after service brake system, steering will have vibrate when apply brake (at
100 km/hr) - SOLUTION FROM NISSAN MALAYSIA: TO SKIM BRAKE
DISC!!!!!! until now my brake disc have been skimmed for 2 times and actually in between the period I have stop them for skimming because I worry on the brake disc thickness. Now I also stopping them since they said they want to skim for the 3rd times.
Current condition of my Car.
Since 6/4/2010 I collect my car until now,
1). 2 unit of my engine mounting broken due to dismantling of engine and have been replaced recently.
2). Knocking sound on steering when turning.
all the above problem still not solve yet and I was so worry every time when I driving the car because I don’t know what others parts will spoil and when the brake system will gone off.
Conclusion
Don’t buy Nissan vehicles, you will regret for your whole life.
Because Nissan Malaysia will not entertain your complaint, they will tell you the parts are under wear & tear category.
Even though fuel consumption is low, but maintenance is very very high.
REMIND : DON’T LET NISSAN No Skill Division (NSD) people check your car because they will twist & turn the facts.
Which Nissan car do you have here?My car was broke down 2 days ago, the car was not giving any response when i press the oil pedal.
My car was checked by 2 workshops by the diagnostic tool and it shows error " P1777- step motor failure" on the gear box diagnostic. I was making the call to Tan Chong Service centre to ask for advise, and they told me that it might be caused by the gear box and it need to be replaced. The cost should be around RM 10,000.00 exclude the labour. FYI, my car mileage is 140,000 km, and the car age is almost 3 years.
My question is how come the gear box can be broken down so easily and NISSAN has claim that this gear box can last for at least 10 years, but warranty just 100,000km. sucksssssss...
This is not first incident happen to me. My car was having different problems since the first day i bought this car.
The following problems shows what has happen to me car:
a. Power Steering Coupling
b. Dashboard has bubble spot : it take 2 days to replace.
c. 3 sets of engine mounting broken on 101,000km mileage (which I has made complaint on it through customer service)
d. Gear Box problem on 140,000km mileage
Well unfortunately most people cannot afford such expensive cars dude!if nissan really good car,they wont need give so big discount to us.we r customer will know which car is good.as we know nissan is last of place in non-national car,first of cuz toyota mabe they got lot of version car to sell off-camry,altis,vios,avanza,invonva,rush,prius,hilux,hiace(van),yet including cbu model 2) honda 3)nissan.everyone know nissan car cant get good resale value as toyota/honda same year and class.now they still want give big discount to boost their sale?how about current nissan owner maintenance their car value right?:stupid: lucky,i never never think want nissan car ever now nissan give discount,toyota of cuz!somemore i hear nissan car really got lot of problem.for nissan lover,u can consider cbu nissan if u really want buy nissan car (fairlady/skyline of cuz) :top:
