Dear detailing Sifu... My car got some damages on the body... One glance at it, no problem... But once I learn to see things through KC's eyes (kena influence), so many of those ugly things came out...
To begin with, my car is 2k white with a clear coat that changes colour over sunlight.
Here are the pictures...
Paint chip off from front left fender
Compared to 20 cents...
I coat it with a layer of clear nail polish. Then repainted it back with the same paint as my car. I got a bit of spare paint left... Now the colour is uneven, dull, rough as you can see. How to fix? Cut-polish that area?
Gap between door and body... Paint chip off...
Gap between front left door and fender... Paint chipped off and got rust (door)
My driver side front door's window frame. I don;t know what the hell is this...
Close up...
Forgot where is this... I think its the near the outer ceiling. Where the door rubber contact when you close the door.
Random chip off...
And this is the place where when you open the front door, you can see... It is also where the door rubber contact and seal when you close the door... What ever you call that area...
Close up...
Car roof water drain... Notice the water drain size increases a bit at the front. I don't know why. Only the driver's side... It becomes really wide..
Close up....
Water drain between the body and windshield...
Rear bumper... bumper is plastic... I understand the chipped off paint part. But there is a part where the paint is on. But it is a bit sunk in. And the colour is a bit different and rough. Why is it like that? Clear coat?
Front bumper
I repainted it myself with the same paint... But soon after that the paint around it started to peel off! Help!
My rear fender got scratched when a bolt hit it... Chipping off some paint...
Please.... Please sifu if you have any tip... I don't mean to make my car dazzling... But I am just worried that if the exposed metal is not treated, it will rust and the rust spread. As you can see, some of the places have paint cracks and rust juice coming out from it...
2. How to fix areas where I have repainted myself but appears uneven, dull, rough and dry? Should I cut-polish the area? But will cut-polish destroy the clear coat and make the whole part appear dull compared to the other body parts? Will it remove the colour-changing effect under the sun?
Thank you!!!!!1
Close up...
Random chip off...
Close up...
Close up....
Front bumper
Thank you!!!!!1
