unable to detect codes now. not sure what had happened. once jumped the socket, the check engine light blink abnormally. not sure what had happen here.
the idling was fluctuating up and down. when the car is cold, start and the rpm was too low ard 500rpm that it dies off all the time. so everytime start up need step on the throttle to give some gas. problem of the iacv solenoid?
it usually starts when you plug in the ecu cell comes of instantly and i hear the relat but turn it off and on again sometimes it still works ok and starts. but sometimes cell wont come off and no relay sound.
change all the caps.
---------- Post added at 11:33 PM ---------- 6 hour anti-bump limit - Previous post was at 11:30 PM ----------
no burns on sta412A
IC17 looks good also
---------- Post added at 11:41 PM ---------- 6 hour anti-bump limit - Previous post was at 11:33 PM ----------
anyone stick the bitumen on the firewall, at the engine side before?what is the effect for sound proofing ?is it noticable?bcoz at 1st i tot wanna open up the dash and put bitumen+superlon...but dare not to kacau the dash since it may create more problem after i open up. so now change my mind to stick on the engine side firewall, but before i do this, can anyone tell me the bitumen can last or not?with the engine bay heat...will it peel of?and is it will help in sound proofing?thanks yea...
