[WTS]Sinfoni Esordio Ad-Lib 4 channel amplifier
ICE -In Car Entertainment
pinkrangerdaddy
Feb 18, 2014
8
Penang
Hi, I have a Sinfoni Esordio Ad-Lib 4 channel amplifier for sale, been driving bmw so the biggest speaker it would take is a 4-inch and this amplifier supplies way too much power for the need, it got my focal 100krs busted. If you interested, you could reach me at 012-470-9911, I would ship and prefer COD in Penang.
Please make serious offer, amp is less than a year old, it is very new, if you need pictures, whatsapp me.
A brushed aluminum titanium finish and white leather design. Its SMD PCB design for a better heat dissipation.Test applied to every single unit and not only to trial samples.
Specifications
Power supply: 10-16Vcc
Input sensivity: 0.1-6V
Output power 4Ω @ 12V: 85Wx4
Output power 2Ω @ 12V: 120Wx4
Output power mono 4Ω @ 12V: 200Wx2
Frequency response: ±dB 10Hz-50KHz
Signal/Noise ratio: <90dB
Dimensions (WxHxD): 280x50x245mm
Weight: 3.4Kg
Built in
Active crossover module continuously adjustable from 40Hz to 250Hz low pass
Active crossover module continuously adjustable from 40Hz to 1KHz high pass
Bass gain adjust from 6dB to +12dB at 45Hz
Good day
Assuming i already have a paint code, lets say i have a Lexus Paint Code Glacier Frost Mica (Paint Code 074).
Which / where is the best shop that i can send my car to for repaint to this EXACT same color as if it was out form the factory ?
(Within KL/PJ Area, and for reasonable price -meaning not dirt cheap, but not dirt expensive)? Would appreciate any recommendaitons. THanks guys !
