HKS Hipermax III for CRZ
1.Newly designed reinforced rubber upper mount
Reinforced rubber upper mount for street use. It prevents noise and durable. (Pillow ball upper mount is used for some vehicles.)
2.Dust boots for both inverted and normal types
It protects shaft from incoming stones.
3.Single tube type / Ride height adjustable lower bracket
Single tube type for high driving performance and ride height adjustable lower bracket to have best styling. These mechanism enables smooth & comfortable ride as well as ideal styling.
4.φ65 Straight spring
Proper spring rate is selected for each vehicle model. It is strong against performance drop and metal fatigue.
5.Large flow capacity piston
The large flow capacity piston produces linear damping force in proporition to piston speed. It enables natural handling.
6.Aluminume lock nut, ride height nut
Lightweight and anti-corrosion.
7.30 steps damping force adjustable mechanism
30 steps adjustable mechanism enables wide adjustment range.
Used for 8000 KMs (LOST Wrench - can use others)
Price Firm with free HKS Front Tower Bar
