[WTA]the recommended engine oil for 4age20v
jack84
183
HI ALL,
i wanna ask every1 about, what is the recommended engine oil, grade and brand for 4age20v. Previously i was using the Motul 20-40w mineral, But now i am thinking to try other brand engine oil. So any recommended engine oil for me . :confused:
Thanks .
Garyyapp
71
Am1 semi-sythetic 15-40
better response but bigger valve sound because Motor Oil(cair).
benjaminn78
671
i only use Motul 300V 10/40, use 4100 turbolight b4, cant stand for hot temp, reach genting, turbolight oil temp 145C, with 300V , 130C.. high rev all the way up to genting.
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Currently using Toyota Semi-Syn 10W-40... you can't go wrong with this!
jsawkang
78
Kuching
i'm using mobil Super S 10w-40
caleb_5375
1,293
well ever since my bt is in my car i use few type ...Idemitsu semi and rockoil and amoil...idemitsu not so easy to dry up compareto amoil....rockoil not bad oso ....when use rockoil the responce goes faster and the engine silent alot...u can feel the smooth of it ....but sayang can't stand high rev much ...need to add selalu
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Bro pcmoddingmy,
the engine oil that you mentioned, how much is it going to cost ?
Usually RM75 for Toyota Semi-Syn 10W-40. I heard its OEM from Pennzoil.
jsawkang
78
Kuching
last time toyota engine oil usually from castrol
jack84
183
Thanks for everyone's advice and suggestion, i really appreaciated.
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Are you sure bro?
Coz some AE chassis come out from factory with "Pennzoil" recommended sticker on the engine bay. Also, if you look at Pennzoil bottle, you will find "UMW" label on it. So I think UMW is the official distro for Pennzoil in Malaysia... and also for Toyota Malaysia.
KHWONG
3,937
36
i am currently using Q8 formula Advanced Semi syn.. 10/40w ... performance very light can feel up to 4000km.. 4 liter pack about RM 89 .. but my fren told me the price being increased..
any1 can confirmed?
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Heard of the Q8 Semi-Syn 10W-40 too... but Mobil Semi-Syn 10W-40 also about the same price, I think.
Yeah... almost everyone also telling that the oil price will go up. WTF!?
nappx
2,532
185
5,163
kLaNG-kEy_tEE
any1 can confirmed?
YEA PRICE WILL INCREASE..ANYWAY WHO WANT Q8 OILS CAN CONTACT ME:itsme: ..HE HE HE (PM)
ajnone
920
7
5,018
Klang
I am using Motul H-tech 100 plus fully syn 5w30.
About Rm140 per 4 liters.
Engine feels very light and good performance.
20v trompet
2,024
Aichi, Japan
Coz this oil build for toyota engine...
ok i have this minor problem which to me, is annoying =(
i changed my rims and tires recently. to fatter/thicker tires (50 to 55 series) and silly of me, to not take note of my new rims offset. so apparently the offset is lower (wheel jut out more) and i only notice this when i take corners at high speed. my tires rubs against the fender.
what i did was, i adjusted the rear camber -ve, so it wouldnt rub on my fender. that's settled.
now my front is also touching, when i do kamekazi...
