[WTA] Max boost of C20B Turbo
zeus83
979
55
KL-Damansara
Just curious,
what is the highest boost level you guys have tried with the stock C20b:hmmmm:? which is found on the 3rd revision of the infamous 3SGTE engine.
Reason: planning to get boost controller:biggrin:
ericgtmythos
184
13
Kedah
ya ya.. I also want to know!
Bro Zeus, I have use boost controller set at 1.0bar, condition OK.:top:
But dun no how about 1.2bar. Coz I have view some info from net 3rd gen 3S-GTE
can affort 1.3 bar as max with ori C20B turbine...so wat do ur think?? ..:hmmmm2:
zeus83
979
55
KL-Damansara
some say factory boost for C20b is 1.4Bar....which in reality will not apply due to age factor....im aiming at 1.1Bar...not sure if can tahan:hmmmm:
now stock boost is 0.9 MAX
this thread is open to any C20B user (and not necessarily 3SGTE) :)
tom's
2,865
76
subang
www.zerotohundred.com
1.4bar max......my mr2 i did 1.4bar twice......more than that, say bye bye to ur fins....hahaha....my mr2 used to set low boost 1bar...high boost 1.2bar
ericgtmythos
184
13
Kedah
:itsme:Sifu Tom's, is that any boost cut for ur MR2 or ur ST205? only using boost controller can fix the high boost 1.2bar d?? I would like to boost up too for my Celica, any advice plssss...:adore:
zeus83
979
55
KL-Damansara
Tom's was using boost controller.....
Tom's,
which one u recommend for our turbo's:
HKS EVC
Blitz SBC
Greddy PRofec
Thx
zeus83
979
55
KL-Damansara
Bro Zeus, im using APEXi AVCR to controll my boost, dun no Tom's using wat type??
yeah....forgot abt the Apexi...;)
wats ur boost cut now? try setting the AVCR to 1.1 and c.....:driver:
ericgtmythos
184
13
Kedah
Yup... I will try since already plan. Is because I hear that Tom's have set his MR2 high boost in 1.2bar d, if get his advice will easy the trouble shooting during setting...hi hi hi..:biggrin:
zeus83
979
55
KL-Damansara
Try since u have it bro! n lets us know the results:burnout:
tom's
2,865
76
subang
i'm using hks evc 3 on both celica n st205.......if 185 or mr2 225 ecu boost cut at 1 or 1.1bar....for 205 n mr2 245 no boost cut.......1 thing good about hks evc it comes with scramble boost function & can download the manual & quite easy to set.....makes sure u change fuel pump n add fuel regulator 1st.....both my mr2 & gt4 running aftermarket ecu.......
zeus83
979
55
KL-Damansara
ic....so stock fuel pump cant tahan the 1.1/2 boost right?
btw i just dyno n got 245PS~240whp @ 0.8 Bar...not sure if thats ok....:hmmmm:
tom's
2,865
76
subang
245hp is quite high.......but na & turbo gearbox will give diff hp rating coz of diff gear ratio & final drive......
ericgtmythos
184
13
Kedah
Ohh...IC... is that means even stock ECU ST205 also without boost cut right? only we have to make sure the fuel pump & fuel regulator to support it. Am i right? :rolleyes:
zeus83
979
55
KL-Damansara
correction: 245wPS not HP so ~240whp:biggrin:, how do think will be the power o/p when getting the E153 G/B??
---------- Post added at 09:35 PM ---------- 6 hour anti-bump limit - Previous post was at 09:33 PM ----------
still wondering abt the same thing....
