Hi to all sifus, What's the maximum Compression Ratio we can use for 97 RON?
Thanks in advance
Thanks in advance
i think around 12.2~12.5 lar....Hi to all sifus, What's the maximum Compression Ratio we can use for 97 RON?
Thanks in advance
If using high cams can go higher, is it?i think so too, cause my friend bumped up him comp to near 13,and was not on high cams,he experienced very bad knocking.had to use thicker gasket to lower it down....so should 12ish should be fine.
Sorry, totally baby in this
Hi, i have jun stage 3 kit with power fc, how high can i go with the CR using 97 RON?with high cams you can bump up compression but you also need a piggyback/ecu and good tuner to ensure you dont detonate your baby.
---------- Post added at 09:36 PM ---------- Previous post was at 09:27 PM ----------
with high cams you also need stiffer valve springs (aftermarket) to avoid valve float.
with higher lift cams potentially allows more air to be rushed into the combustion chamber,and this is when you need a piggyback/ecu to be fine tuned by your tuner to ensure everything runs smoothly.
honestly bro i am not very sure...AD EG...wats the highest compression ratio for rotary? FC3S
dats i mentioned i really not sure...coz i have insufficient knowledge on rotary engines...and i am in no position to post about it...ok ok...but rotary no cam...so many things 2 learn...rotary like so complex yet so little moving parts onli
