Will JPJ Disturb if i install Turbo Kit On my 4g91 Engine
Starkiller
544
71
Hartamas
What car bro?
Starkiller
544
71
Hartamas
naah dont think they disturb la. i heard Kenari with VTEC pass JPJ roadblock no problem(maybe give duit kopi). JPJ very unpredictable, my car also stock engine kena tahan at JPJ roadblock lol.
wsukun
695
785
1,593
London Calling
any unapproved modification to engine bound to be problem to JPJ. No?
star, your neo no exception. with such modification to the front end, you got more hard days coming ahead to you
Starkiller
544
71
Hartamas
hahahha, i sense it coming too bro :sad: but that aint gonna stop me from modding!! :D
mydvdrom
105
lets juz say its not as illegal as changing to a turbocharged engine. some theory is that it is safe as long as u don't change the engine illegally. another school of thought is that a big increase in power for a standard engine might be illegal. but does that mean that NA cars with heavy mods that can't be detected by visual legal? lolz
yeehau86
Feb 10, 2007
2,868
2,425
maximum displacement increase is 25% according to their law, make sure you don't exceed it.
one1002
140
10
its just a turbo kit..no the full engine correct?
then i guess its ok..just dont kepishh kepishhh infront of them.. =P
that is when u want to change your engine..mostly proton, jpj doesnt allow you to change to a 2.0 engine..1.6-->1.8..1.8-->1.8..only perdana can use 2.0 engine.
yeehau86
Feb 10, 2007
2,868
2,425
I was replying to mydvdrom actually since he is talking about big increase in power for a standard engine might be illegal. :burnout:
MKMD428
876
190
5,043
johore
yup..and if i'm not mistaken, turbo are considered as accessories. its a kit. in car registration card also stated, eg: 4G63, 4G61, 4G93...etc it doesn't state any 'T behind. as long as the engine number is the same as per engine blok.
so the conclusion is..i think its ok. its an accessory for engine.
kumar22mostwanted
1,562
152
HELL!!!
yeap yeap there is no rule againt BOT
the reason they may stop you if they see intercooler or hear BOV sound is coz they think you may have changed your engine without approval from them
however if you still have the same engine as stated in you grant then it should be all good for u even at roadblocks :top:
xtremeleo
3,247
464
the jpj regulations have this grey area on how much u can mod an engine, is it dependant on the power figure, parts, etc? if its ur original engine, den charge it up all u want sir
Mrnazmi
510
29
3,028
Drag City
But for further confirmation, i suggest u should go check with puspakom of JPJ officer first because if you can get legal statement from them that bolt on turbo on non-turbo engine does not need inspection, then it should be ok lor..:driver:
But for my experience, two of my friend:
1. Wira 1.5 (original Proton Engine) bolt on turbo + big inter cooler, got roadblock by police only, easily pass without further question.
2. Kelisa 1.0 (original Perodua Eninge) bolt on turbo + big inter cooler, got roadblock by JPJ, been asking by the JPJ Officer whether he change the engine or bolt on turbo, my friend simply open the bonet and show the JPJ officer his engine is bolt on turbo, then kawtim, no further question / explanation, the officer just let him pass.
Both situation is no further question / explanation by by both officer (JPJ and Police) , so still don't have legal statement regarding bolt on turbo cases. Hope anyone can add some more experience..:proud:
xtremeleo
3,247
464
thank you mrnazmi for enlightening dat up, like i said, no problem as long as u r using the original engine. ive checked and asked so many times to the jpj, and their response was like "kalau tak tukar engine takpe". dis statement was led because they dont have a clear guidline on how much modification can be done to keep the car street legal. can u change to a higher compression pistons even with the same bore? can u change to a better flow air filter? how much is the maximum gain in horse power allowed if any modification is done? questions like dat are the few examples that they cant answer clearly, loop holes if u must. loop holes dat are very good for us imo
lucian^^Gk
115
5
Sarawak
which mean 1.3cc car if wan do engine transplant only can opts of engine with 1.6cc... :bawling:
btw, if do engine transplant then install turbo kit !!! illegal ? :hmmmm:
93na
597
20
if bot is ok! as long dont change block! but as for the intercooler try not to show it off too much! u might get stop for it! but as long as engine asal is ok! been there done it!
Mrnazmi
510
29
3,028
Drag City
Agreed with xtremeleo, all those BOT thingy is not clearly been clarified by the JPJ, so consider it legal as soon the engine number is correct, all the safety system been upgrade (breaking and suspension) then it should be ok..:driver:
A Post Every 5 Mins
I got my Mercedes Bend E300 just 4 years and it only clock 10,000 kms, i don't drive it often that is bcz i do have a few more cars at home. I always follow the service schedule as Cycle & Carriage recommended and always cost me thousand & thousand. As usual i sent my car to C&C Segamut a couple days ago for full service and i did ask them help me have a look on my air cond system because some time will take like 5-10 mins to work, at the 1st they said could find anything, they will flush my...
