What Engine is the best for Neo ?
ishwinder
50
I need some help. What is the best engine for satria neo. Without JPJ Problems.
neohadri
200
34
the engines that was designed to fit in it's chassis from the factory, the almighty campro:love:
or u can plonk in 4g93t
ColdPlay
288
112
yes. campro cps and mod it to the max. i have driven a friend's neo cps fitted with 4g93t and its more of a drag machine.
too much rear end sway during fast corner. f:r weight ratio increased big time bars and suspension offer little improvement in curbing the
tail wagging.
peeche
395
165
Sin City, MY
tail wagging.
even the stock neo easily oversteer during hard corner..
pel
'(00)
174
Cyberjaya
Maybe some performance upgrade(stage 1,2,3) from r3 would be good enough if don wan jpj problem.R3 is currently offering stage 1(ecu,exhaust) upgrade for 2k IINM. No need to worry like doing engine transplant.
ishwinder
50
i was planing to go for gsr ck. but now having second thoughts. engine kinda expensive. i am driviing a Neo with campro engine. roughly 150 ~ 160 Whp d. but am worries if i bot campro engine. it wont last. so i am lost ~
ishwinder
50
Exhaust System
K&N air filter
iridium Plugs
Plug Cable
Camshaft
Works Fuel rail
campuley
crank pulley
Fuel Regulator
Unichip Q piggyback
from the top of my head i can remember these.
But now i wanna go Turbo. but i donno what to do. because i am using campro only not cps. so i am not sure. should i go campro turbo or go gsr ck. or is there a better choice ?
quicksilver7
313
66
528
Exhaust System
K&N air filter
iridium Plugs
Plug Cable
Camshaft
Works Fuel rail
campuley
crank pulley
Fuel Regulator
Unichip Q piggyback
wow looks like you've spent close to 10k.. why not just go turbo from the start lol
ishwinder
50
Enjoy na first. Now i wanna enjoy turbo. So donno what to do. I need some advice. And some views. If i turbocharge my campro. I think i will be roughly 210 whp. Will it start to have problem?
Now I am using the 4g93 eterna machine.I want to upgrade the performance with added with mivec parts.I planned to:
- Change throttle body and intake manifold with MIVEC intake manf and TB
- Using the adjustable cam pulley
- Port and Polish
- Change the piping with 2' piping and mivec extractor
- Using the HKS intake powerflow
The question is, Can the modification above is effective to increase horsepower,torque and topspeed.How it can increaseHP? What the cost range to make the...
