Waja CPS recommended battery
Recommended
  • Dry
    Votes: 0 0.0%
  • Wet
    Votes: 0 0.0%
  • NS60
    Votes: 0 0.0%
  • NS70
    Votes: 0 0.0%
  • Total voters
loose_end
3,649
197
Malaysia
1) Why does conti like BMW need to use DIN type batteries ?
2) If use smaller size like NS40 for bigger cc, what is the negative effect ?
DIN is German specs, Conti cars usually uses DIN batteries....
If use smaller battery, not sure got enough juice to crank up and you may need reserve for whatever gadgets to power...
If I recall - it's the CCA (current) amount that matters, the DIN is the size. BMW uses those deep cycle batteries for longer lifespan and it can handle the sudden draw of current. Normal batteries will have a very much shortened lifespan if used in a car with large draw.
egb18c
922
94
kuantan
Iam using ns70 for my gen2 without battery bracket, well iam not using my gen2 for touge driving. Its just a town car.
The main reason for using ns70 wet type is basically financial reason.
1)ns 70 last longer than small battery.
2)ns 70 wet type will last longest from my reading.
3)ns70 has much better CCA than ns60, its a better choice if you relocated your battery. DIN type battery has more powah than NS type battery.
4)better gounding,its a must, grounding cable shall be exact or better size than the power cable.
Have a nice day
Have a nice day
Hope your alternator can support the bigger battery. Otherwise you're just spoiling the larger battery faster.
sweelt
Nov 6, 2016
2,306
248
663
Penang
Have a nice day
Figure out where to put bracket. Duno when will hit pothole, battery jump. We dun want postive terminal touching body. Maybe tiny posibility, but play safe.
Doesn't work that way. Need to change the tray and bracket hook position. My car fits NS60 and 70, but the 70 can't fit the brackets even with the newer bigger ones. Damn kacau.
Mine no tray, just find another place to hook at the bottom. My old school probably have plenty space until newer cars and my Hyundai uses the bottom clamp to hold the battery. That is why need to buy battery with the notch at the bottom.....:driver:
Speaking of which the NS70 I bought had a base that was jutting out. Damn damn damn kacau
can a 4g63turbo gearbox work on a 4g93turbo .......to me they look like they will bolt on each others engine the same ? HELP :hmmmm::hmmmm::hmmmm:
