waja alarm
sifuconman
25
503
Hi
Recently my waja alarm went off by itself frequently even after I disconnected all the door, boot and bonnet switches.
I want to dismantle the alarm and repair it as I know a little electronic.
Can some expert advise me where the alarm module is hiding and how to dismantle the waja alarm system ?
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Hi
How is your battery?
If its in good shape (above 13v or close) with engine off then i think it could be wiring problem.
Since u have basic then u know how the switch work to trigger the alarm right.
I think nothing is wrong with the box as it react to whatever signal it get from the trigger point.
For the location,i am not sure for 1.6 model but for 1.8 its behind the glovebox.
Near the cobra immo box.
sifuconman
25
503
Hi Gunnerzz
My battery is brand new - just replaced about six months ago. I suspect the alarm main module is faulty because I had disconnected all the switches and yet the alarm still triggers.
Thanks for the information on the alarm module location. I'll try to located the module and fix it. Mostly probably is caused by some dry solder joints
My waja is 1.6 auto.
Battery voltage should around 12.6v with engine off.....:biggrin:
Usually if battery problem means power to alarm is cut then on again, just like when remove battery terminal and then attach back again the alarm will go off....
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
713
Hi Gunnerzz
My persona is at the left boot. Dunno same or not.
mosesmk
165
32
Selangor
Hi
Hi
You need to open center console, including gear knob console. Then take off the coin container. alarm unit sat underneath it. once you open everything you can see it.
sifuconman
25
503
Hi
Thanks.
Now my alarm is completely spoiled and not working anymore.and need to replace an after maeket unit. Any one has a copy of the wiring diagram for the alarm ? Is it using positive or negative output ?
Thanks
mosesmk
165
32
Selangor
Hi
Thanks.
Thanks
Need to dig my note. i will post it if i manage to found it. it is not a complete pin out. but will help as much i could.
i've changed my power steering fluid
the prob is the day i've change my power steering fluid, my steering runs smooth i the steering is very light
but after 1 week, my steering return to the previous condition that the steering is hard
what is the prob?hw can i do with it
i've asked my friend and he says got air inside the power steering hose and he teach me to repair it. he teach me to turn my steering over and over again when the engine is on. i've tried but nthng happens
