~An oxygen sensor wrench is specially designed to check, remove, or install oxygen sensors, which are often located in confined spaces.
~Oxygen sensor wrenches, which may be of the socket or claw type, come in a variety of forms, although the standard size is 22-mm(7/8 inch).Some are heavy duty or have a pneumaticaction for use on rusted or baked-on sensors.Others have an opening or slot down the side to avoic having to cut the wires leading to the sensors if the device is only being checked.
~Most oxygen sensor wrenches will work with the majority of sensors found on vehicles.Sets are available which may contain a number of different sockets and wrenches, including offset wrenches, heated oxygen sensor sockets, and vacuum switch sockets.
