tyre rotation
flat_tyre
88
hi guys,
is it really important to rotate ur tyre on certain times? im running on kyb rs abs in front (means short stroke)and standard abs at the back, with 15' rims.
i found out that my kyb rs cannot support bigger tyre series, only 50 below, since im using 15'... now, my front tyre is 50/15, rear tyre is 55/15... :P
flat_tyre
88
bcoz the tyre will hit some part of the abs...
i did compare stock abs and my abs, can see the difference... the space between the abs and the tyre is very close... i mean VERY close...
correct me if im wrong, im still a noob :P
My car have idling problem every morning.
My gearbox is auto.
The car always have high vibration when the car stop on "D".
But this problem go away when is afternoon or at night.
There is no problem for this until i had install turbo.
Could it be:
1) at idle speed, i believe that turbo is turning and i guess there is extra air entering into engine cause too learn?
2) at idle speed, i believe that the inlet pipe is too long and cause less air, so insufficient air into engine cause...
