yup that's true mr Z... n one more.. which pin should we jumping the cable at diagnosis pin? like 4AGE we have to jump TE1 to E1 pin b4 doing a diagnostic n see the trouble code....are you talking about trouble codes found via diagnostics?
not sure, bro...I've seen it done with a test set connected...the guy did an interrogation, but found no faults...so, can't help...any sifus can help out? maybe you should try asking William from Trial...yup that's true mr Z... n one more.. which pin should we jumping the cable at diagnosis pin? like 4AGE we have to jump TE1 to E1 pin b4 doing a diagnostic n see the trouble code....
tq...
Similar threads | Forum | |
OBD-II B1421 error Codes,PLS ADVICE. | The Altezza / IS200 / IS300 Forum |
