hahaha~ stock absorber work best on wish, just the problem is wish's spring normally start failing after 5 years~ best change your spring together when you change your absorbers, it will make your absorber last longer~ (* and your car's rear might sit a bit higher then current position as well as new spring were still retain it's stiffness)~
