External dimensions
- Length (mm) 4275
- Width (mm) 1760
- Height (mm) 1460
- Wheelbase (mm) 2600
Weights
- Kerb weight (kg) 1290
- Gross Vehicle Mass (kg) 1805
- Gross trailer weight braked (kg) 1300
- Gross trailer weight unbraked (kg) 450
Engine
- Engine type Petrol
- Capacity (cc) 1798
- Engine description Four cylinder, in-line, DOHC , four valves per cylinder with dual variable valve timing, alloy block, cross-flow alloy head.
- Configuration In-line
- Head composition Light alloy
- Variable valve timing Standard
- Variable valve timing type Dual VVT-i
- Valve gear type DOHC
- Number of valves per cylinder 4
Fuel
- Fuel type Unleaded
- Fuel type octane no. 91
Power
- Maximum power kW 103
- Rpm for maximum power 6400
- Maximum torque Nm 173
- Rpm for maximum torque 4000
Fuel system
- Injection type Multi-point injection
- Variable intake manifold Standard
- Ignition type Electronic
Fuel consumption - ADR 81/02
- Fuel consumption - combined (L/100km) 7.1
Emission control level
- Australia - greenhouse rating 7
- Australia - air pollution rating 8.5
More info here Toyota Corolla specifications Levin ZR Hatch Manual
p/s : i wonder why Toyota doesn't continue it's VVTL-i engine system :hmmmm:
