Toyota Levin Return
D7zul
2,697
848
Shah Alam
External dimensions
- Length (mm) 4275
- Width (mm) 1760
- Height (mm) 1460
- Wheelbase (mm) 2600
Weights
- Kerb weight (kg) 1290
- Gross Vehicle Mass (kg) 1805
- Gross trailer weight braked (kg) 1300
- Gross trailer weight unbraked (kg) 450
Engine
- Engine type Petrol
- Capacity (cc) 1798
- Engine description Four cylinder, in-line, DOHC , four valves per cylinder with dual variable valve timing, alloy block, cross-flow alloy head.
- Configuration In-line
- Head composition Light alloy
- Variable valve timing Standard
- Variable valve timing type Dual VVT-i
- Valve gear type DOHC
- Number of valves per cylinder 4
Fuel
- Fuel type Unleaded
- Fuel type octane no. 91
Power
- Maximum power kW 103
- Rpm for maximum power 6400
- Maximum torque Nm 173
- Rpm for maximum torque 4000
Fuel system
- Injection type Multi-point injection
- Variable intake manifold Standard
- Ignition type Electronic
Fuel consumption - ADR 81/02
- Fuel consumption - combined (L/100km) 7.1
Emission control level
- Australia - greenhouse rating 7
- Australia - air pollution rating 8.5
More info here Toyota Corolla specifications Levin ZR Hatch Manual
p/s : i wonder why Toyota doesn't continue it's VVTL-i engine system :hmmmm:
Supra_Fanatics
20,685
3,998
Corolla Manual!!!
But not in Malaysia wor...
TitanRev
You think I print money?
Mar 3, 2005
8,210
3,678
My mum n dad drove this levin when they were at Aus....manual 6 speed...
mototo
102
31
5,028
NSW
a workmate of ours has the previous generation levin zr. pretty feature packed. exactly the same one in this ad
►►► 2008 TOYOTA COROLLA LEVIN ZR ZRE152R 4cyl 1.8L Hatch ◄◄◄ | Cars, Vans & Utes | Gumtree Australia Strathfield Area - Homebush | 1032901277
i thought this was the bees knees of corolla hatchbacks
then i stumbled across a blade master g TOYOTA BLADE MASTER G | 2008 | BLACK M | 23,000
3.5l v6 thats usually found in the Aurion's shoehorned into a corolla hatch body! helllooo torque steer
RENESIS VIII
7,063
950
Ipoh
New Levin eh? The last one that I know would be the AE111 Sprinter Trueno BZ-R but is that counted as Levin? I wonder how will this new one fare against those old 4A-GE Levin.
BTW, I notice that the TS is really a big fan of Toyota. Very knowledgeable about Toyota stuffs from what I see from his posts.
Supra_Fanatics
20,685
3,998
Sure TS own the Levin Bzr.....:smile:
D7zul
2,697
848
Shah Alam
RENESIS VIII
7,063
950
Ipoh
Haha.. No la.. Mine is Levin AE101 silvertop..
Only my ecu n gbox is BZR :biggrin:
Means AE101 Coupe? If it is, then you've got a nice car there. Rare car, never seen those before. But I've seen AE92 Coupe before.
D7zul
2,697
848
Shah Alam
AE111 comes in a few different trim :
- Corolla 4 door (auto n 5spd)
- Levin BZG (auto n 5spd)
- Levin BZR 6 spd
- Trueno BZG (auto n 5spd)
- Trueno BZR 6 spd
- There's also BZV
There's a catalog for this.. I'll try to find it n post here
---------- Post added at 10:54 PM ---------- 6 hour anti-bump limit - Previous post was at 10:46 PM ----------
Yup.. Mine is ae101 2door coupe
Pics in my profile here :wink:
---------- Post added at 11:12 PM ---------- 6 hour anti-bump limit - Previous post was at 10:54 PM ----------
can drift ah??:biggrin:
Nope.. It's FF
Front engine, front wheel drive
RENESIS VIII
7,063
950
Ipoh
- Levin BZR 6 spd
- Trueno BZR 6 spd
- There's also BZV
Nope.. It's FF
You really are the king of Toyota in ZTH. :adore: Next time if I want to get any Toyota, must consult you first for advice. I have Toyota also at home but that was just a lame Toyota.
All those Levin and Trueno come with 4A-GE 20 Valve?
D7zul
2,697
848
Shah Alam
Yes, AE111 Levin n Trueno comes with 4A-GE 20v blacktop
N thanks 4 d compliment
I believe there's a few Toyota kings in here but they r a bit bz to post :wink:
---------- Post added at 11:41 PM ---------- 6 hour anti-bump limit - Previous post was at 11:39 PM ----------
Btw, what Toyota do u hv?
RENESIS VIII
7,063
950
Ipoh
I see. I guess these are the cars that are normally being cut up for halfcut shop. I think there is still one more Toyota using 4A-GE 20 Valve, Corolla Ceres. That one had frameless doors which is kinda like a mini version of Chaser and Mark II. Nice looking car but I think that one is very very rare over here.
We have all sorts of experts in ZTH in different sectors. Toyota, Honda, Mitsubishi, Mazda Rotary, Proton, etc... ZTH is the place where experts gathers and share their knowledge. :biggrin:
BTW, you're more familiar in which type of Toyota cars/engines? The NA engines like 4A-GE, 3S-GE or the turbo engines like 3S-GTE, 1JZ-GTE, 2JZ-GTE?
D7zul
2,697
848
Shah Alam
I'm quite familiar with 4AGE.. coz I'm using it :wink:
The rest i know with d help of mr google :biggrin:
Why did u ask?
RENESIS VIII
7,063
950
Ipoh
Why did u ask?
I see. Just asking only because I also notice that not many are familiar with the turbocharged Toyota engine.
Talking about 4A-GE and Trueno/Levin, I have a question that I have been wondering for some time. I found out that there are two different types of head for AE101 Coupe and I had no idea what is their difference.
Yours is which one? Got any difference between this two other than the fact that the one with air scoop is using 4A-GZE?
D7zul
2,697
848
Shah Alam
the 1st pic is AE101 Trueno 4A-GZE
2nd pic is AE101 Levin 4A-GE
the 2nd pic is the same model as my car..
30,002
Can mod your Toyota in future....:biggrin:
---------- Post added at 10:03 AM ---------- 6 hour anti-bump limit - Previous post was at 10:03 AM ----------
Bro. Dzul, your number plates also can flip up ah?....:driver::biggrin::biggrin:
RENESIS VIII
7,063
950
Ipoh
But there are also some with and without the air scoop. Like this
Means there are also AE101 Trueno with 4A-GE and AE101 Levin with 4A-GZE? Technically both cars are the same except than the engine?
A supercar that has no comparison. Called the Lamborghini Reventon. Its extreme coherent style, angular sharp lines and inspired by the very latest aeronautics.
Only 20 units will be produced, the Lamborghini Reventon is a symbol of exclusivity and extraordinary performance that makes this controversial Murcielago LP640 so unrivaled. Born in Sant’Agata Bolognese and inspired by...
