Originally posted by DJ-EVO3@Dec 8 2004, 13:17
I meant .. the radiator cap.. it's leaking from the top.. is it a problem???
or natural...???
any leaking is definately not natural, cos if it was natural they wouldn'y call it a leak, maybe call it 'flow' haha.. anyway if u got the time just get a replacement lo. dont think its that urgent if ur temperature levels are ok.
anyway... i strongly advise against using external device or anything that dosnt come stock stock e.g. fuel regulator etc to cover your engine faults...
thats like cheating...
imagine if a stock car has no odd problems and has reasonable standard power yet dosnt require an aftermarket device..
why should yours?
I think aftermarket eqipment should not be bought for the sake of rectifying a problem but to enhance yr current setup.
search thoroughly for the cause of the problem, get it fixed...THEN only think bout aftermarket device.
i believe stock setup is a good baseline to follow as its factory proven. once u achieve that, then only think of custom upgrades. that way u will also be able to isolate the causeshould anything go wrong.
