the Blind and the Beauty
zckid
235
238
543
Mauritius
Hi friends
I got to work on a BMW, my first German ride. In our small island, it embodies beauty, quality, comfort and pride.
However, its eyes have gone from worst to blinded. i had to restore the same with a little patience and a lot of passion.
Please enjoy the transformation..
Upon arrival
Headlights washed and clayed
THE LEFT SIDE
Nearer... not appearing a much damaged as the right side...
Let's see what close inspection reveals
From different angles
Extreme close-up
A medley of defects from swirls to deep scratches and...
.... stone chips ... so many of them
starting to turn opaque.... and
... OMG..... this hurts
a very deep scratch...
Correction in progress...
Localizing remaining defects... and
TA DA
same same but new.... only restored with Almighty's grace
Transparency is the only acceptable standard
the LED is not forgotten
Hello!
Remember
Now
THE RIGHT SIDE
Close -up
Blinded beauty
Like a brick wall, it should have a very high score on the opacity scale.
Can you see the LED?
Another view
close-up
and surprisingly it was hiding many more defects underneath it.
The Afters
Transparency is the key
Light allowed to travel
Right side done
The ex-brick-wall headlight
Remember
Now :nomore:
Beauty revealed
Thanks for reading. Your comments and thoughts are most welcome.
cheers
Zaid
Impronte
132
13
518
Penang
nicely derive..
dunno when is my baby turn.. glass full with watermark, body full with swirl, headlamp look like both sights (rabun defat&rabun jauh) already..
zckid
235
238
543
Mauritius
thanks so much for your encouraging words buddies
Great work! among all detailing I love headlamps restore the most!
:top: the beauty lies in the eyes
defining work of the master
still noobie la :biggrin:
nicely derive..
learned from the sifus, many things can be done, with a little and a lot of passion :idea:
really eye opener article!
thanks buddy, here's what i did, thought of sharing it before, but simply forgot
here's what i did
Basically an inverse zenith method to go least aggressive
Washed with a MPC available locally
clayed with Uber clay
Wetsand 1500 grit mirka sandpaper with megs sanding block
Got down to 800, then 600 (still little done in terms of correction)
Coarser grit 400 then 320 grit mirka sandpaper
moving up to 600, 800
Still higher 1500 grit (Sifus' rule at this point i made sure i removed the 800 grit marks- didn't have the 1200 grit paper)
Refined with 2000 grit and finally with 2500
Compounded with Menz PG S34A on 4" LC orange pad via Makita rotary
Polished with Menz 203s on 4" LC wool via the rotary (to get the best of both the cutting power of the wool pad and the smoothness of 203s)
Finished with PO85rd on 4" LC white via the makita
sealed with Menz PowerLock
hope it helps :itsme:
Veloc
3,234
991
Sabah
Nice job. I know this takes a lot of time and patience as BMW's headlamps are so hard.
Impronte
132
13
518
Penang
nowadays manufacturer almost using plastic 'eyes'.. are there any difference process for both materials.. (glass&plastic type)?
Yup, thanks.
Did follow some of your work done, will post when I compile the pictures for my first headlamp challenge....:driver:
Hi,
I have some questions.
1. Will there be any difference, if I change the injectors? I'm currently running a 4G13P. Is it a necessary for me to get a adjustable fuel regulator afterthat?
2. If I choose to use High cams 272 degree, what kind of settings or precaution should I take note, in order not to let the car stall?
Thanks.
