The best Aftermarket Absorber
cyhppro
Nov 28, 2010
20
I am looking for the best in comfort, style, handling for a car..Koni.Bilstein,Tein,monroe and etc,which is the best?Any experience or recommendations for purchasing the best absorber brand?
I used honda accord 2.4 05 model..
p/S;sory,i was posted this recently at general car..I post this again to get more information
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
u cant get best of the 3 world (comfort, style, handling)....
u either go for either one or make do with average performance for all 3...
Turborized
138
19
518
Probably can get best of 2 worlds? I'm using GAB Hi-low soft-hard. Comfortable and handling.. Hentam genting corners no problem. But I think that's just me. Tee hee.
kumar22mostwanted
1,562
152
HELL!!!
i would recommend TITAN then you will definitely be guaranteed performance
and i think style comes with all adjustables coz u can adjust it low or high depending on what floats ur boat
cyhppro
20
oo..i am looking for absorber that lowered a bit to my car but comfort like ori..if not 100% like ori abs,80% also ok..how suggestion of otai2 here.tq
JINEIL2EN
Over 10,000 RPM!
15,317
525
3,213
Island Of Pearl
team99ers.2.forumer.com
the only 1 can answer ur call, thats Koni FSD.
kumar22mostwanted
1,562
152
HELL!!!
hmm...koni is good?any experience about tein?
titan not much information about it
the best way to get info about titan is to actually go to their shop and ask them any query u have
im sure they will be more than happy 2 help u clear ur doubts
---------- Post added at 05:44 PM ---------- 6 hour anti-bump limit - Previous post was at 05:41 PM ----------
if you want to lower ur car with 100% the same comfort as the ori absorber and performance is not an issue all u need to do is cut the spring a bit
JINEIL2EN
Over 10,000 RPM!
15,317
525
3,213
Island Of Pearl
if u do watch F1 or u ever drive a Lambo... then u'll know Koni is good onot...
Tein?? not my cup of tea at all..
shiroitenshi
3,676
170
That's if you're already using linear springs in your car (e.g. coilovers) The trait of linear springs is that they are the same thickness, and same diameter from top to bottom.
But then, with this kind of suspension, can just lower by adding compressing the spring using the spring compressor on the coilover body. This one comes with the smaller spring, called the helper spring.
If you're looking for comfort, never use coilovers.. even the models with helper springs are quite stiff. Tien Super Street is quite soft, but it's not as comfortable as standard ones.
Standard suspension does not use linear springs. They are progressive. you can see this by how the top coil, middle coil and bottom coil not the same size.
This sample is a comfort lowering spring.. car is lowered, but still comfortable.
Standard proton springs also are progressive, that's why people who cut their springs find it harder/stiffer.
---------- Post added at 07:03 PM ---------- 6 hour anti-bump limit - Previous post was at 06:59 PM ----------
If you're using accord, I'd recommend bilstein.. The normal version, not coilovers.. Quite comfortable, okay handling, but not track handling, ok?
Do not get the bilstein coilovers if you plan to carry your family in the car.
kumar22mostwanted
1,562
152
HELL!!!
oh dam i forgot this part
too used to adjustables already
forgot what normal springs like :rolleyes:
but i remember proton the standard spring is linear
when i swapped my adjustables out last time
shiroitenshi
3,676
170
Hmm.. not sure about that... last I ride in a proton with chopped springs, sakit tulang belakang lol.
kumar22mostwanted
1,562
152
HELL!!!
oo realy ah??
i thought cuting the spring would just have cosmetic effects i didnt know it makes the ride more stiff :hmmmm::hmmmm:
no experience with using lowered spring though
cyhppro
20
wow..that what i want..what model of koni that suitable to me?
---------- Post added at 04:15 AM ---------- 6 hour anti-bump limit - Previous post was at 04:08 AM ----------
that is,use coilover will not suitable for comfortable acievemnet?koni high tech(luxury master)is good or not?i am afraid buying a wrong model of koni or tein..bilstein b6 is good or not?
I am about to change the manual gearbox oil and the rear axle oil of my car. The car is RWD corolla and non LSD equipped and standard as can be.
My question is.
How much Tuffoil should i pour in the gearbox and the axle? 1 bottle for gearbox and half for axle? Or half for gearbox or half for axle?
Can tuffoil be mixed with grease? I intend to try it for wheel bearings.
I saw a big bottle with a truck picture being sold in ACE. Is the contents same as the regular bottle?
Is there...
