Technical Guide: How to tune the VAFC
udengfahlawi
1,350
12
putrajaya
Ok, on popular demand, I start this thread for anyone who knows how to setup/configure/tune the VAFC (or VAFC II), to share their knowledge about it...so that perhaps later on we can learn a little bit on how to use the thingy...rather than having it in our car for the wrong reason (like admiring the lights at night, etc) or having to rely on workshop to do the adjustment for us (and cost rm100+ each time)....
so anyone...please throw in your experiences...
p/s I don't have a unit yet...need to make sure I know how to use it first....:regular_smile:
shiroitenshi
3,676
170
Well.. due to udeng's request.
THIS IS FOR VAFC only
Provided you understand this one fully,.. VAFC II is the same.. so is the NEO... just certain features are accessed differently.
For those that worry about losing revenue out of this:
.. since these people playing with old school VTEC, and not i-VTEC.. means any means to save a little money is a good thing.. let those that play i-VTEC play with the newer, more expensive VAFCII systems.. hahaha.. I oso know a bit about VAFCII and i-VTEC.. but that one newer tech.. so won't kill business for the fellas doing 'tiuning' for the newer systems. These old school fellas like me are CHEAPSKATES.. bwahahaa.. so given a choice of expensive versus not doing at all.. sure will be.. NOT doing at all.. hahahaa!!
First.. do up the wiring... follow the wiring diagrams... for B16A ecus follow the diagram.. earlier versions (like the one I had is missing the VTM wire diagram) but later versions should have it already in the manual. If you're having check light issues or whatever.. always check the wiring first. I recommend buying a harness so you don't butcher your original ECU wire harnesses.. Fields harness adaptor is quite cheap, and a worthy invesment if you're going to install many many meters like the RSM, VAFC, etc, etc, that requires butchering the original wiring.
If you're unfamiliar.. PAY someone to do it.. you can cause some expensive damages with improper wiring.
First of all.. after installing, DO NOT START THE ENGINE IMMEDIATELY ...
Just turn the ignition to on.. so you can get the display out....
So, first you need some basic settings input into the unit. You can delete the old settings if you want. Use the [Initialize] option to do this. It will ask for confirmation... say yes and viola! a blank VAFC unit without any settings.
You can do a sensor check first for fun. this is under the [Etc] > "4. Sensor Check" menu. Just check various sensor readings.. usually I just check the TPS and be done with it.. just to make sure that the sensors are okay and not reading absolute zero.. which usually means wiring problems/improper connections.
Now, choose the sensor values, car type, etc. This is in the [Etc.] -> “1. Sensor Type” menu. This one refers to the the MAF sensor, if I'm not wrong.
The Sensor Type is 06/06 for hondas.. It's stated in the manual.
Then go to [etc.] -> “Car Select”
CYL (number of cylinders, this is for the RPM reading off the ignition signal, if I'm not wrong) which is of course 4, unless you're running a V6 in a civic.. :P
Thr. This is the TPS sensor. TPS sensor type is the arrow pointing up to the top right corner.. (0-3/5V) for honda (that's why you do the sensor check first... in case you have a TPS sensor that's 'lain daripada yang lain' (i.e. problematic one) after set.. calibrate the throttle position.
It's not written in the manual, but the throttle position cailbration is done like this.
(in case depressing full throttle isn't getting VAFC to read 100% in the [monitor] mode. Sometimes you don’t even need to do this.. I think it’s because some TPS sensors aren’t giving voltages close to 5V, so it doesn’t read that 4.5V as full throttle.)
With the highlight on the Thr. setting.
Don't depress the throttle pedal... Count to ten.. then press full throttle and don't release for ten seconds. (I forget which one came first, so just reverse the procedure if it doesn't work).. use the [monitor] mode to check the throttle position (it will be in %)
With that set up.. you're ready to start your engine.
Start it up, and it should either idle properly (like stock lah!) or sputter (if you jacked up the fuel pressure/bigger injectors)
Considering you're new to this.. I won't begin with trimming fuel off modded engines with fuel pressures at 4 bar and up, or using bigger injectors.
With your engine idling properly.. go to the [monitor] functions and explore... This won't screw up anything.. and it justs displays various stuff for the 'oooohhh!!! aaaaaahhh!!!!' effect.. :P
Section 1
First thing you might need to set at this stage is the VTEC unmatch point if your VTEC isn't engaging at the right RPM.
Firstly set the “V/T Cont” to a RPM you want VTEC to open. In this example… I set mine to 5500rpm on, 5400 off.
Go to the [monitor] mode... and choose the two relevant channels (RPM and VTo) that will be used for this.. (you can choose all four if you like, personally I choose only two for the bigger letters/numbers )
Run and read the VTo (VTEC output signal) and see where it light up.. it should highlight at some RPM.. release throttle, and note at what rpm the VTEC signal turns off. Compare the RPM to the number you set in “V/T cont.”
Go to [setting] -> “V/T Unmatch” You can use these as a baseline.. but might have to add or reduce 1% or more.. Remember that VTEC point for H22A, and other VTEC engines are different due to different ECUs, that's what this setting is for in VAFC.
Hi<<Lo = ±2%
Lo>>Hi = +3%
The proper way of doing it is noting the RPM differences when VTi and VTo light turn on and off in [monitor] mode and getting a percentage out of that.. but in reality.. that takes too much brain power and calculation…..
So you can simply “wing-it!” (i.e. balun aje!) and you’ll get it roughly right after a couple of tries.
Modify these numbers until you get VTEC to turn on (and off) at the right RPM. (note that all RPM readings I’m asking you to read from are from VAFC, not your DASHBOARD TACH!)
The time which VTEC opens on the engine is the VTo signal (VTEC output signal from VAFC) and the signal for the VTEC from the ECU is the VTi (VTEC input signal) Strangely the manual never mentioned about this… Apexi really sucks at making manuals. :P
Section 2
With that VTEC unmatch point done.. your VTEC cross-over point should be spot on.. which means if you set to 5500rpm, the VTO will turn on at 5500 rpm, and will turn off at whatever RPM you set. That’s it for [Setting] -> ”V/T Unmatch”
I follow the rules from hondata, which means that VTEC hi cam should not be turned on before 3K rpm, and should not be turned on too late at 6K rpm and up. (Hondata states that the it causes some problems due to the rocker arm configuration in Honda engines. I don’t know the exact details.. but I consider hondata people to be more knowledgeable than me.. y’know?
Now we progress on to the T/H point.. this is the setting for part throttle and full throttle. What it means exactly is this.
VAFC has dual maps.
The full throttle air correction map’ [Setting] -> Wide Thr.
The part throttle air correction map, [Setting] -> Narrow Thr.
This will become clearer later!
The T/H point setting is simply this. (I put an example setting)
Lo = 50% / Hi = 80%
What it means is this.. If your TPS position is 50% or less, it will use the air correction map from [Setting] -> Narrow Thr.
If your TPS position is more than 80%, it will use the air correction map from [Setting] -> Wide Thr.
So you can tune for fuel economy for part throttle, and more power at full throttle.
So what happens if the TPS position is 60%? (I know this question will come, since this was what I wondered at first as well!)
Answer: The VAFC will calculate the air correction based on the air correction map from [Setting] -> Narrow Thr. AND [Setting] -> Wide Thr The calculation on how VAFC ‘extrapolates’ the air correction % is inside the manual (I never bothered to remember.. look it up yourself!)
As for the “T/H Point” Setting.. there is no correct setting.. it’s up to the individual.. For me.. I set relatively mild air correction, sometimes up to 15 A/F on part throttle on lower revs (1-3K rpm) for fuel economy.. so I set mine at 50%.. where most of my daily driving is done… while at 80% and up.. I give quite high air correction rates for more fuelling and top end power.
If you want a recommendation.. I’d put 50% and 80% as a good setting for T/H point (feel free to set it to whatever.. just remember how it affects which air correction maps VAFC will use like I said above)
Section 3
Now on to the tuning..
Using an A/F meter (you can go without it, if you just want to tune for fuel economy, and you UNDERSTAND the LIMITS of ‘leaning out’ your engine’s A/F) Just be sure that you know how to identify sounds of knocking…
AS ALWAYS… LEANING OUT YOUR ENGINE AFTER VTEC IS A BAD IDEA!!! Unless you have an A/F meter so you know how much fuel you’re REMOVING! (sure.. you can play around with -1% or slightly more.. but I'm not responsible if you detonate your engine at high RPM)
The map should look something like this (Without settings.. there should be just a flat line.. I took this out of a screenshot in google..)
Under [Setting] -> "Wide Thr."
Simply put.. since the VAFC uses air correction rates to increase / decrease fuelling, you should be able to see the effect on the A/F meter each time you tweak the air correction rates.
For purposes of explaining.. consider that each time I say add fuel, that means I added more air correction on the LOWER part of the graph.. when I say remove fuel.. I added more air correction on the UPPER part of the graph.
So.. let's begin with the full throttle map which is under [setting] -> Wide Thr.
If you don't have a dyno.. you can do it on an empty street (hopefully without people that will complain of excessive noise).. Since this was initially for people without a dyno set.. here goes.
Get a guy with a timer.. and time how fast the RPM climbs (at a higher gear than usual.. maybe about 3 for 2-3000rpm test, 4, for a 3-4000 test.. etc.)
So from XXXX rpm to XXXX rpm.. set that air correction value for those two RPM points.. try again.. gained time? then set some more till you get the shortest time to get from xxxx rpm to xxxx rpm.. (means your torque increased)
Move on to the next range. Finish everything up and to check fuelling for the highest RPM, do a few passes, reach 8K... slow down and check the plugs.. are they fouling? If yes, you're running to rich (remove fuel a bit).. if whitish tip, too lean.. . (add more fuel)
After setting the [setting] -> Wide Thr.. you can go on to [setting] -> Narrow Thr. (part throttle).. since you already have the baseline for the Wide Thr... you can roughly set this by seat time in the car.. (Means you drive around and tweak till you get just nice pickup and smooth acceleration) It won't be much different from [setting] -> Wide Thr air correction maps.. but you can play with sub 3000-4000 rpm air correction to get some fuel economy.. (jimat minyak).. Again.. don't go overboard.. 1-3 percent from the Wide Thr. settings is a very safe adjustment to make (if you're running Lo = 50% at [Setting] -> "Th-point"
All rules still apply.. make sure you know that you AREN'T REMOVING TOO MUCH FUEL! ESPECIALLY ON THE HIGHER END OF THE RPM RANGE!
Okay.. that's it for the important parts. The other parts.. well.. they're not very important, but feel free to ask if you want to know.
shiroitenshi
3,676
170
Woah.. this is a lot of work.. you guys should belanja me for a TT sometime.. :P
Still got more.. break time!
tougevtec
24
OH my GOD !!!
This is GOOD !!! I was about to invest on a SAFC NEO... Now with this.. I will surely GET one :)
accord21
93
just wnt to know? the highest rpm on vafc??8k or 10k??how about vafc2 & neo?..
shiroitenshi
3,676
170
9K for VAFC 10K for VAFC2.. NEO... I don't know! :P Someone buy neo and loan it to me for a week.. sure I know how to tune one.. Bwahhahahaa....
With the stock RPM points.. it's only 8K for the VAFC but you need to spread out the values a bit..
For example.. for now, it starts at 1K, and there's a air correction point for every 500rpm.. so it ends up at 8K.. spread the numbers (in the [Setting] -> Ne-P:HVt and [Setting] ->Ne-P:LVt so that it spread at every 600-700rpm, and bang! you got that 9/10K... The spread is totally customizable depending on your need.. so it's also a personal choice.. no definite, sure-fire setting.
REMEMBER THAT A STOCK P30 ECU only MAPS UP TO 8K (or whatever ECU you're using at the moment with it's rev limit) , and VAFC doesn't remove the rev limit... NOR DOES IT CREATES MAPS past that stock rev limit... so not much point for doing it, unless you're trying to tweak a chipped mugen/spoon ECU with a higher rev limit and higher RPM mapping for various reasons (usually because of different setup than 'spoon or mugen' recommended specs.
Finished for now. :P
J101
1,304
malaysia
this whole portion of the paragraph should be bold. really bold. :)
harpoon
607
7
shah alam n amp
i guess...for oem, u wont reach above 8k due to the limit set up in the ecu.
heck, it already limit itself to 7.5-8k, so anything more dun have to put data what....
zaki
328
Oderf said:
very easy la udeng...even udeng jr can play with the buttons....hahahha...i think better install AFR meter for reference...
do not use the Apex'i TT AFR to tune unless if you want to tune for cruising part. but anyways, the AFR is still not accurate enough.
zaki
328
you can really write la shiro. restecp!!!
one more thing you forgot. how does it(piggyback) work? hehehe
shiroitenshi
3,676
170
This one you oso know what... don't kedekut ilmulah.. even if people learn.. the the time it takes to tune.. not everyone can find the time.. esp. those that are willing to pay for them.. :P
Still VAFC is a limited tool for tuning.. but you can do some workaround to get around those limitations. But seriously.. the setting available for 50% air correction is maddness! I don't think I've ever needed to go past 15% air correction to remove fuel yet.
Here goes:
Piggyback works by simply modifying the original ECU signals.. Certain piggybacks DOES have mapping feature for the extended portion after 8K. (where the stock ECU doesn't have)..
Standalones are fully customisable.. but getting a basemap out is not very easy.. unless you already know about the baseline setup for the engine you're tuning... Usually standalone ECU companies provide these basemaps.. but not all.. :P
While the Civic Type R is a model of precision engineering, the Civic Hybrid raises the standard for environmentally-friendly, advanced automotive technology.
