technical data
Kitz
42
Penang
Yo....... im looking 4G93T technical data...... whos got it..??
. And also looking for brand new greddy type s Blow off ......
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
technical ass got la.. hahahaha what u want? wiring diagram for ECU?
greddy type ass no stock la market.. hahahaha
turbonetics
513
is this wht u looking for?? hope it can helps...
This The Original Mitsubishi GSR 4G93T Spec:
CHASSIS
E-CD5A-SNGF (GSR)
E-CD5A-SDNF (RS)
E-CD5W (wagon - libero)
PRODUCTION YEAR: Oct'91 to Oct'95
TURBO SYSTEM
Make IHI
Model No TD04L-13G-5
Waste gate opening pressure 78 kPa
FLUID CAPACITIES (litres)
Engine oil pan
(with filter) 4.0
(without filter) 3.8
Manual transaxle 1.8
Engine coolant 5.0
Reserve tank 0.7
Fuel tank 50
Power steering 0.9
Transfer case 0.5
Rear differential 0.8
LUBRICANT SPECIFICATIONS
Engine Conforming to the requirements of the A.P.I. classification "For service SE (or higher)" having a low phosphorous formulation suitable for use in vehicles fitted with catalytic converters and with the correct S.A.E. viscosity grade number for the expected temperature range.
5w30: below -30 to +10 deg C
10w30: -20 to +40 deg C
15w40: -15 to above +50 deg C
20w40: -10 to above +50 deg C
Manual Transaxle Hypoid Gear Oil; API classification GL-4 (preferred) or higher
viscosity No. SAE 75/85W, 80W
Rear differential Gear Oil; API classification GL-5 or higher
viscosity No. SAE 90W or 80W
Transfer Gear Oil; API classification GL-4 or higher
viscosity No. SAE 75W-85W, 80W
Power steering Dexron II Automatic transmission fluid
Engine coolant Mitsubishi Long Life Coolant at the specified concentration by mixing with demineralised or rainwater only.
Front and rear Wheel bearings Lithium Base "Multi-purpose" E.P No.2 grease
DIMENSIONS (mm)
Overall length 4275
Overall width mm 1690
Overall height mm 1385
Wheelbase mm 2500
Track
- Front 1450
- Rear 1460
Ground clearance mm (unladen) 150
Turning circle - kerb to kerb 10.2m
Seating capacity 5
MASS (Kg)
Kerb Mass (with tank of fuel) 1190
GMV 1680
GCM 2430
Air Conditioning +20
Power Steering +6
Tow Bar +15
Anti Skid Braking +17
GMV = Vehicle Mass + Payload
GCM = GMV + Trailer and Load
TORQUE SPECIFICATIONS(Nm) .
Cylinder head bolts
- hot engine 80-85
- cold engine t 20 + ¼ + ¼
Camshaft sprocket bolts 90
Camshaft bearing caps
- M6 11
- M8 24
Main bearing cap bolts *25 + ¼
Crankshaft pulley to sprocket 12-15
Connecting rod cap nuts *20 + ¼
Crankshaft sprocket bolt 185
Flywheel/drive plate crankshaft bolts 100
t = Tightening angle method after initial tension to 75 Nm then completely loosened.
* = Tightening angle method
GENERAL ENGINE DATA
Engine 1.8litre
Model 4G93
Type 16v Double Overhead Cam
Bore mm 81
Stroke mm 89
Displacement cc 1834 1834
Power Rating DIN 70020 141kW @ 6000 RPM
Torque Rating DIN 70020 249Nm @ 3000 RPM
Compression Ration :1 8.5
Compression Pressure 935kPa
Firing Order 1-3-4-2
Valve clearance (hot)
- Inlet mm Auto
- Exhaust mm Auto
Valve Timing Intake Valve Opens BTDC 19deg
Intake Valve Shut ATDC 53deg
Duration 253deg
Spark Plug Type NKG BK6E
Bosch F7DC
Nippondenso K20P-U
Spark Plug Gap mm 0.7-0.8
ECI Engine timing (with terminal grounded) 5deg BTDC +- 2deg
Idle speed rpm 750+-100
Specifications so marked were correct at time of publication. If these specifications differ from those on the Vehicle Emission Control Label (in the engine bay) use the specification on the label.
NOTE On vehicles fitted with a catalytic converter a blackened exhaust pipe is a normal condition.
COOLING SYSTEM
Thermostat opens 77 deg C
Radiator cap release pressure 75 to 105 kPa
TRANSAXLE
Type Manual
Model W5M33
Gear ratios 5 Speed
1st 2.916
2nd 1.684
3rd 1.115
4th 0.833
5th 0.666
Reverse 3.166
Primary reduction 1.680
Transfer gear 1.090
Final drive gear
- front 2.936
- rear 4.525
BRAKES (mm)
Front Ventilated Disc
Diameter 204.0
Thickness
- Std mm 24.0
- Min mm 22.4
Lining pad thickness 2.0
Disc run out 0.8
Rear Solid Disc
Diameter 224.0
Thickness 10.0
Disc run out 0.8
Wheel speed sensor clearance
- front Fixed Fixed
- rear 0.3 - 0.9
Master cylinder Tandem, dual proportioning valve with 'x' split system
Bore diameter 22.2
Booster Master Vac Diameter 180/205
Brake pedal height 162-165
Brake pedal freeplay 3-8
Park brake lever stroke 5 - 7 notches @ 200N
WHEEL ALIGNMENT
Front suspension McPherson strut, coil spring
Camber (non~adjustable) 0 deg +- 30'
Caster 2 deg 20' +- 30'
Toe-in (measured at centre of tyre tread) 0 +- 3mm
Toe-in Angle 0 deg +-0 deg 9'
Toe-out angle on turns when outer wheel at 20' 21 deg 12'
King-pin inclination 12 deg 49'
Rear suspension Trailing arm multi link
Camber 0 deg 40' +- 30'
Toe-in (at rim) 0.5 +- 2.5 mm
STEERING GEAR
Type Rack and pinion
Steering wheel free play 10-30 mm
CLUTCH
Type Single diaphragm with single dry disc
Diameter 215 x 140 mm
Pedal free play 6 - 13 mm
Pedal height 162 - 165 mm
Release bearing Self centering type
WHEELS AND TYRES
Wheels 14" x 5.5" JJ
Tyre 195/60R14 85V
Pressure
- Front 210kPa
- Rear 200-210 kPa
Rim runout max lateral\radial 1.0 mm
ELECTRICAL
Battery 272 CCA 49 minutes
Alternator 12v with integrated voltage regulator
Output 65 A
FUEL SYSTEM
Type Multipoint electronically controlled
Fuel pump Electric in tank
Pressure 335 kPa
Fuel type Unleaded petrol only
ECU
5663 = Lancer RS
7377 = Lancer GSR
7737- gsr rs
5537 - gsr
INJECTORS
4G93T - 390cc
MIVEC - 240cc
VR4L:200, VR4:220 - 450cc(blue)
VR4RS - 510cc (yellow)
13B - 550cc
evo1,2,3 - 510cc (yellow)
VR4 - 450cc
gsr gearbox - W5M33
gti gearbox - F5M22
clutch: 9", bolts
Do i need to change the spring to adjust the front high low so called adjustable suspension ?
Its on a Kenari with a 2.8kg spring (on pervious owner) and now put into my kenari it was too low til it hit my fender and bumper was gliding thru bump.
so i went back to titan and ask them to make the front higher, titan boss mr.richard say have to put in a spacer in the spring and adjust it higher.... he say that is the most fastest and cheapest way. (but not safe lar, i think!)
another way ...
