Starting Problem
resh9999
109
10
Did not start the car many months
. So instal new battery but still cannot start. Upon changing fuel pump, able to start . Its AVS fuel pump. The next morning need to crank numerous times then only can start. Then the car is fine the whole day. Today the same issue. What could be the cause?
Sent from my SM-N910C using Tapatalk
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
are all the ignition parts in good condition? plugs? cables? coil?
if u has a fuel regulator, u can check if starting the engine has fuel pressure or not. if u dont have fuel regu, need to check if the pump is working or not.
if everything mentioned above didnt start your car, u need to swap ecu with other running airtrek. check whether ecu was burned..
The Marketplace Top Posts
i just bought an used gen2 2 weeks ago, and i've installed front and rear strut bars, that makes the handling far better. k&n drop in filter and tufoil oil additive, makes the acceleration more responsive. any other recommendation for daily use? thank you
