Spark Plug Keep On Blown..
BoxShapeMeN
14
I had a problem wit my car.. the spark plugs only last for 1 week!!
What should i do?? can D.I.Y?? or any??
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
impossible sparkplug can only last for a week ler...
check if u've got the correct plugs.... check ur ignition timing and so on.... ask ur mech tune it back for u lor....
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
if ur spark plug got oil when u take it out, then ur valve seal need to change...
BoxShapeMeN
14
not sure bout da ignition timing lar.. i dint kacau it bfore..
but a spark sound came out of engine..
+.. keep on jerkkin on low rev.. my car currently used is atoz..
pagtc
9
Brader
Used the correct spec OEM NGK no BKR5ES-11 with resistor -tread 14mm with spark cap 11mm.
How about yr Plug cable connect correctly.....
BoxShapeMeN
14
thanks anyway guys.. actualy da problem is da stock high tension cable is crack.. can i find aftemarket performence engine parts for atoz or something to fit inside to add more power?? huhu..
Hi there,
Current satria setup 4G91 with waja crank shaft and oversize pistons running afc neo.
Extractor hotbits 4-2-1, custom middle pipping is 2 inch and comes with center box.
Current s-flow small and much back flow.
Cant make up my mind between a bigger slow flow inlet 2 inch or a hks silent hi power straight flow inlet 2.3 inch.
Need some advice.
Thanks.
Kipasa.
