Something wrong NEED help
lynx_210
251
Hi to all sifu....
i hv a mod car but now got bit problem here hope all sifu can gv me a idea here thank you very much.......
when my car rav till 5k rpm (sometime start fr 4k+) it always not smoth n some times sounds like "PopPopPop ...." can any1 help me out ???
tried out used to control the fuel but still the same - or + fuel also same ...... change the plug n cable also the same.....
lynx_210
251
hey guys thx a lot ...... im driving a B8 turbo n the A/f tuning i tried it but not really this problem n the poppoppop sounds is good when ur car can go fast but now only the sound n car can't go over 5k rpm then very sian 1 rite???? any more idea ???? really need u guys help
Thanks..................
Brahandum
82
my car had same problem but now ok already, go change or service ur ignition coil, that might be the problem, atleast thats the problem found in my car, high rev jerk a little and power lost around 5k right? ask a mechanic to check ur ignition coil then kay? =>
just my humble opinion =>
lynx_210
251
Thx again .... i used ignition coil b4 got this problem n now i did'n but still the same problem n also change plug n the cable ........... n i'm 3" straight no bullet
so fren said is my fuel filter do u guys think is this problem ????
Thanks
Redline_club
892
www.redline-club.com
Thanks
i dont think so is tht fuel filter, if fuel filter dirty whn u accelerate the enigne will off...
lynx_210
251
Ok u r rite my car engine not die off ...... but exhause don't think got problem leh....
e819
1,261
check ur plugs
if too white >> less fuel more fire (api)
if too black >> too much fuel >> makes more carbon
its ok if a bit yellow-ish...
try tuning ur car if plug s ok..
my rusty cents
'(00): No man should ever see the pathetic sight of his Supercar, injured by the sidewalk. Even less a barely-year-old LP570-4 Superleggera (The Latest GSL mind you) Reasons for cause aside, this wrecked exotic was seen half on and off the curb with it's passenger-side front substantially defaced and also missing a front wheel...
