Single turbo VS Twin turbo
Hadi17
145
10
518
Johor
why do some prefer single turbo and some prefer twin turbo ?
what's the difference between both of them ? pros and cons ? :confused:
leonl
229
81
USA
What kind of car or engine ? How much HP you are looking ? How much to spent ?
Needs a little more details on vehicle.
Thanks.
ColdPlay
288
112
1,543
Smaller single turbo / smaller twin turbo setup eliminates the turbo lag but it limits the modification level in term of 'milking' the highest power the engine could churn out.
Bigger turbo tend to have the turbo lag effect when the gearing is not play at optimum operation range.
At the end of the day, the engine type, amount of $$$ at your disposal and target horsepower are the main criteria.
Hadi17
145
10
518
Johor
Thanks.
lets put a Skyline R34 as the car .. HP maybe around 350-450 .. anything regarding modding the car we should have $$ HAHA !! which is expensive ? :itsme:
To me is usually engine design. If straight 4 then one big turbo. If V6 then 2 smaller turbo one on each bank....:driver:
Recently I found lubricant inside the air filter area of my 20 over year old Proton Iswara. All these times, even before the full overhaul, I did not have this problem. If I am not mistaken, I think this trouble started after the recent normal service (change oil & oil filter) The PCV valve is not blocked. What could be the culprit of this pressure building inside the crankcase?
