Integrated On Board Diagnostic (OBD2) On your Iphone and Ipad
Video demo using Rev application on iphone
http://www.youtube.com/watch?v=wPzAwInukM0&feature=fvwrel
Video demo using DashComm application on ipad
DashcommandTutorial.MP4 - YouTube
The SGear OBD2 Wifi Scanner is a plug & play device which allow you to connect directly through your OBD2 socket in your car and connect through Wifi with your iOS devices (Iphone or Ipad)
What you need?
Car Model : Support wide range of car which has OBD2 socket (to read more on OBD, click here)
What Display Device I need?
iOS device - iPhone or iPad
What Applications on my device I need?
The following are some of the Apps which you can purchase from AppStore (or some can be downloaded from installous):
Rev - App Store - Rev
DashCommand - App Store - DashCommand - OBD-II gauge dashboards, scan tool, and vehicle diagnostics
FUZZYCar - App Store - FUZZYCar
Speedport - App Store - SpeedPORT
What you need to do?
Plug & Play, simple and easy
Some additional technical data:-
Weight:0.2kg
Technical Specifications
SSID: SGEAR wifi
IP: 192.168.0.10
Subnet: 255.255.255.0
Port: 35000
Range: 50 ft (Line of sight)
Antenna: Internal
Power Consumption: 0.75 Watts (With Power Switch)
Wifi Standard: 802.11a/b/g
Operating Temperature: -15 to 100 Deg Celsius
Plastic: Automotive Grade
Physical Dimensions: 2.75 x 1.25 x 1.2 inches
Description
SGEAR OBD2 SC is capable of communicating with vehicles which adopt following protocols:
ISO 9141
ISO 11898(aka. CAN)
ISO 14230(aka. KWP2000)
ISO 15765(aka. CAN)
SAE J1939
SGEAR OBD2 SC is able to detect and interpret these protocols automatically. It also provides support for high speed communications and a
low power sleep mode. It use AT commands to communicate with a host device (PC, notebook, iPhone, iPod touch, iPad and so on).
There are plenty of software packages available, which are fully compatible with SGEAR OBD2 SC.
Some of them have pretty useful features, such as engine running parameters monitoring, DTC reading and clearing, MPG meter, etc.
You can even write your own software on a specified hardware platform if you wish, because the AT commands are fully documented and
very well explained. SGEAR OBD2 SC is measuring only 2.7 x 1.25x 0.9 inches, and it comes attached with a 6 ft OBDII cable for easy installation.
It is compatible with 1996 and later vehicles. Connecting to your smart phone is made by WIFI connection in adHoc mode.
With proper software installed in the host device, you may have following parameters read out from your vehicle:
Vehicle Speed
Turbo Boost Pressure / Vacuum Pressure (subject to your car ECU reading)
Horse Power & Torque
RPM
Fuel Consumption*
Engine Coolant Temp
Intake Temp
Fuel Pressure
Calculated Engine Load
Throttle Position
Intake Manifold Pressure
Air Intake Temp
Timing Advance
Mass Air Flow
Fuel Level
Barometric Pressure
EVAP System Vapor Pressure
Fuel Trim
It includes:
SGEAR OBD2 SC
CD(manual and software)
Delivery Charges:-
For POSLaju delivery +RM15.00
Normal delivery - FOC
Please PM me for further enquiry and payment advice, thank you :)! Happy Driving and Monitoring
What you need?
Weight:0.2kg
SSID: SGEAR wifi
IP: 192.168.0.10
Port: 35000
Antenna: Internal
Description
ISO 9141
ISO 11898(aka. CAN)
ISO 15765(aka. CAN)
SAE J1939
Vehicle Speed
RPM
Fuel Consumption*
Engine Coolant Temp
Intake Temp
Fuel Pressure
Throttle Position
Air Intake Temp
Timing Advance
Mass Air Flow
Fuel Level
Barometric Pressure
Fuel Trim
It includes:
SGEAR OBD2 SC
Delivery Charges:-
