Satria Neo engine transplant
thomasysl
31
Hi all
This is my first attempt on engine transplant. I just found a half cut 4G92 MIVEC Auto/Tiptronics (CK4A), have anyone here done a transplant on Satria Neo? Anything I need to take precautious on? Will I be able to use back the Neo dashboard? Any advice and suggestion will be great.
Thanks.
Regards
Thomas
kob3bryant
484
wah,wat a waste.if transplanting is ur concern.u should not waste ur money end up buying a new to car to mod.coz the ck version 4g92 mivec do not as popular as the previous version.and i personally think tat tis kind of g/box is fun to play,but it is sad to repair
acbc
4,615
KD
Rebuilding an auto gearbox is worth the money but u send it to a specialist who will break open and upgrade all the clutches, seals and mod the torque converter. Cost can be from RM 5k to 10k depending on model.
alexz
626
do take note that the satria neo has totally different engine mountings compared to the CK4A/Waja/Gen-2. The neo has only 3 engine mountings. you may have to fabricate an adapter to install the engine onto your original neo mountings.
mag9556
2,770
43
Are u sure or not... new.. very new car u know...
Satria Neo is nearly the same as Gen2 and wht engine that Gen2 can put in, the same as Satria Neo..
Then as putra 4767 said becareful on the mounting side...
Lopot
396
K.L
Should be an interesting result when you done. But source the info carefully.
acbc
4,615
KD
Gen2 can use Evo4. How they mount it? No idea... perhaps they use Evo4 crossmember?
thomasysl
31
Hi all senior members
Thanks a lot for the responds. What I have is a Satria Neo 1.3(A), the torque is hopeless when it is under 4000rpm(I do most city driving). SInce it is a very heavy car (1100+ kg), a better choice would be a 1.6 engine, but the campro is not my favorite. I bought this car is because as a authorised Proton dealer, need to purchase one a demo car. Other than the engine, the Satria Neo does have a stiff chassis, it feel good on the highway. So thats the reason I am thinking of performing a engine transplant.
Isnt that Gen2, Waja and Neo has the same number of mounting? sicne there are all using the same engine. Let me check with my machinics on this, else fabricating the mounting is out of the questions. If I cant use CK4, any other recommenedation I can look at?
Thanks again to all.
Regards
Thomas
khoyos
2,632
156
5,163
Shah Alam
other than mivec, there's also a variant of 4G93T in CK form. i think jpj approval is an issue here.
p/s why on earth did u choose a 1.3? and auto???
thomasysl
31
As I said earlier, it is a demo car. So going for the cheapest option. So thats the reason why I am looking at the engine upgrade. :confused_smile:
Regards
Thomas
alien
2,564
5,138
kuala lumpur
so changing the engine..
the car being new,sayang and all tat is not an issue for thomas here..
i guess we shud just focus on wat engine options he has..
as he's decided to do the transplant..
thomasysl
31
Hi all
Alien, thanks. I guess the reason is "Why did he purchase 1.3 auto at the first place?". It is a Demo car that we dealer is asked to purchase during the launch. So for that reason, I chose the 1.3(A), but I was quite disappointed with the engine, especially the low torque at <4000rpm. I have no complain with the body, in my opinion it is the second best chassis and handling ever produce by Proton other than Savvy. The interior dashboard area is solid, althought it still uses those cheap looking material. So the advice and suggestion need from all your experience sifus is how should I improve it. The CK engine option is out of the question, as comfirmed by my machanics, the engine mountings are different. So 4G16 SOHC or the Campro 1.6 engine are also out of the question right, since there are all using the same mounting as the CK. So what is left for me, is exhaust system upgrade, filter upgrade, grounding cable, lighten pulley and etc which will add up more that a engine upgrade and does not guarantee better improvement.
This is just too bad, as the Neo does have a very stiff body which can handle higher power engine. During the launch, I ahve many GTI owner scame and ask bout the Neo, but when they found out that it is using the Campro engine, they just said "No thanks, lets wait for Proton to have a engine other than Campro, then I will consider.", see thats the general comments.
How about changing the cam shaft, pistons and etc in the engine, is there such an option out there? But the Siemen ECU, .... sigh...:sad_smile:. If nothing else, may be I should take out all the seats, damping material, carpets to lighten tha car. :hmmmm2:
Thanks.
regards
Thoma
ealt
2,395
16
You can try VW golf gti.It's 3 point mounting same as sneo...
rollakid
4,936
5
Kuching Sarawak
i got a question: how durable is the s.neo 1.3liter engine, and gearbox? there will be a limit to what you can do with the engine, and IMHO it is best to research a bit into that. If the "limit" isn't enough to satisfy you, then might as well do not mod the current engine.
and ultimately the budget too, unless you say the sky's the limit.
thomasysl
31
Not sure about the durability and limit this engine can substain. However I have decided that I just need improvement on the torque as the first priority. Since this is a demo/test drive car, it is better not too mislead anyone who actually tested it.:_: I will go for the Hotbit exhaust system, drop in K&N filter, mythelogy lighten pulley, HOt Inazma HVS type LR and may be some ground cables. :regular_smile: It should cost about RM2000++.
Thanks all who responded. Merry Christmas and Happy New Year. Cheer:beer_yum::present::beer::party::dancing2:
Regards
Thomas
gavan
1,408
Shah Alam
whoa~! you add all those performance bits into the car then how the testers would feel the car is better than compared to stock?
my car wira 2.0 vr4 stolen ad taman putra perdana puchong, aroynd 4.30 am yesterday 25/10/2011
below my car pic....flat number WEL 1613.last info my car still ad puchong area.....any information about my car please call/msg 0173018951.
