Satria 4G92 SOHC to DOHC
softmuffin
384
hi there all ZTH users.
just want to know izzit possible to change my satria 1.6 4G92 SOHO to DOHC w/o changing the engine to mivec? And after SOHC to DOHC. if possible can you list out the,
parts:
price:
Where to find the parts and where to fix it.
thanks
RTSi
79
Originally posted by deep_thinkers@Jan 24 2005, 09:08
i need info on this kind of mod too... please help...
<_<
I think just change block to 4G93..
That's all..
my friend already swaped 1.6 block to 4G93..
erm..not bad. :rolleyes:
alvin24
3,109
27
5,148
Yes its possible...
I forgot the complete list of parts you'll need... complete 4G92/93 head (4G91 head won't fit... water jackets tak ngam, engine bore size different so ur compression might be effected if u use 4G91 head, reliability might be a problem too), change of timing belts, new gaskets, etc etc.
Total cost will go up to around 2k++.
You'll probably get around 10hp more from this more (if not less).
Equal priced alternative with much more power increase: high cams + rechipped ECU
Why don't wanna change engine? If u change to mivec... the engine code will still be 4G92, therefore jpj inspection would be unneccessary. Just go there for an engine number change... can do it on your own for 30 bucks like that.
Good luck on your mod... if not mistaken this has been discussed before oso.
RTSi
79
Originally posted by alvin24@Jan 24 2005, 13:30
Yes its possible...
Yeah Alvin....
agree ! :rolleyes:
HyperRevved 6313
230
Cheras
parts:
price:
thanks
Change engine straight away .... Don waste few thousand juz to increase a little bit more power ....
moppy
273
I've converted mine using 4G91 DOHC and so far no problem running.
The cost I have spent is about RM14xx. This including polish and overhaul top head.
If someone quoting RM2k, then it's better to change the engine and no point getting a little power increase.
moppy
273
With proper workmanship, it should reliable. My bro, has using it for more than a year without problem. Do u think is reliable? His engine using 4G91 DOHC head, without any problem. No wear n tear and no problem occur.
partyJOE
2,221
tumbs up
oh u mean u r using 4G92P wit 4G91 head ha...
maybe u can explain more abt this mod here....
which workshop? parts? etc etc...thx
moppy
273
Me, is 4G92P + 91 Head
My bro. is 4G93P + 91 Head
I've been running for few months without any problem.
My bro. has running more than a yr also without problem.
Basically this is what you need for conversion
1) The DOHC head - RM400
2) Top Gasket - RM130
3) 4G91 Distributor - Rm150
4) Oil n Timing bearing - RM116
5) Timing Belt - Free
6) Timing Tensioner - RM100
7) Engine mounting support saddle (LH) - RM45
8) Engine mounting - RM30
9) Oil n Timing Seal - RM24
Labour to fit and overhaul the top head - RM350
Polish - RM150
Hope this help.
Excalibur
732
NoWay2Run
Why dont just go for this(PIC)... Is ready to "ta pou" back those F**ker whose lin C with thier new stock 4g63 & stock 4g93...
There tought that just change engine & the car can go very fast lah..... Can bully small cc car lah... let 4g92 bully those big cc back...!!!(soon)
moppy
273
Are you comparing a
4G92P Turbo with NA 4G93 or 4G63?
Or you comparing a 4G92P Turbo with 4G93T and 4G63T?
softmuffin
384
Hello dude, cool information
how about the workshop?
Polish - RM150
Hope this help.
softmuffin
384
Hello dude,
I just feel a bit weird for you brother case. Since ur brother is using 4G93P why want to change the head to 91. pick up or for fun ...
anywhere no hardfeeling
Polish - RM150
Hope this help.
moppy
273
softmuffin said:
Hello dude,
No heart feelings.. n no offence. Well this is the problem. Many ppl cannot tell the different between 4G91 n 4G93 head. Maybe for you guys quite technical a bit then only know. Just like my bro. he know nothing. Actually it's a conned job. The mechanics charge him for RM800 for everything and told him is 4G93 head. Sound very cheap right but there's a story hidding behind. Ok let me cerita a bit, this is an experience. Hope you guiys nvr fall into a trap again.
There's once I almost also kena conned. There's one guy in autoworld forum selling the head and I was in doubt and finally at that time one of a guy i knew from the forum he is interested into sohc to dohc and finally i have allowed him to do the conversion. First I don't know it's a conned job and I hv tried my best to explain to the guy. Finally he also understand cos the person who sell the head I also not meet b4. At the end found out the head is from carb head. I felt so sorry to him.
The cost for everything is RM800. Head included plus siap pasang dan jalan.
This mechanics sucks, he took my bro. intake manifold and put in imported 4G91 DOHC manifold. The problem is EGR missing and a lot of carbon being collected inside the piston. The cable for auto cruise took away (but my bro. found it early and ask it back). The old head being giving to him. The timing belt is not 100% new. When the bullet start to making tick tick tick noise my brother asking my help to repair it and since mine one done is good in Ipoh, therefore I took my bro. car back to Ipoh and do a top overhaul. I can recommend this mechanics is very good. He's very good into stock car, turbo or modification car, he cannot do. He has a lot of manufacrturer manual that's why he can do kinda job like blue printing.
Ok back to the cerita. When he took out the head, he found the EGR is missing, not the original intake manifold. The timing belt is wear n tear about 40%. When he did the top overhaul, I could easily spotted the head of the piston were covered by a thick carbon. He said the reason bcos no EGR.
I have done a lot of research into differences between 91 and 93 dohc head.
Obviously the piston cylinder size on the head is different. 78.4mm vs 81mm
2) Cam profile different
3) Valve spring is different. 93 is 5mm higher
4) The inlet air/gas hole for 91 is smaller. The exhaust if I am not mistaken is the same.
There's 2 ways to verify whether is 91 or 93 head.
Measure the cylinder size. Or get a venturi/gasket for the 93 manifold inlet, you could check it and compare.
Since the problem found out. 91 head matching 93 block, my mechanics suggest my bro. to port the inlet hole as big as 93. The polish it. Well the head can be ported at the end. The only cannot be changed is the cam profile and valve spring. The cylinder remaind it and didn't overbored it cos it's not so important. Overall is just a few cc different and not worth to spend rm100 to overbored it.
Anything you wanna know, I can share.
I just converted to a GTi engine and sold my head in a package for RM600. The head just done top overhaul and only few months usage.
moppy
273
Finally my last advice, becareful those ppl who do the sohc to dohc for you. Many of the market is 4G91 head. There's very limited of 4G93 DOHC halfcut coming in. Also how many ppl doing Mivec head transplant?
softmuffin
384
Alamak in that case i also scare.
there is lots of power different using an 4G91 and 4G93 head
btw if you dont mind can you go with me when i do the sohc to dohc thing.
the total cost is around Rm900 for me also..
what ur location and phone no?
Hi.. Guys..
Need your help here.. T_T
My lovely swift being stolen today(9-9-2010) at prima setapak's car park (genting klang area)at 8.30pm..
blue colour swift..
sport bodykits..
ori rims..
carbon sticker on the hood..
WSS9247..
any have saw this ride pls alert me.. thx..
EDISON-0102125026
appreciate your help to spread the news
thanks
