Saga LMST FC RM 50 --> 200 KM only?!
Apr 13, 2012
Kuching
Hi all,
I search through the forum and found that normal Saga LMST FC is around 320KM for RM 50. But my Saga LMST FC is RM 50 for 200 KM only! Anyone can guide me what should I check for this ridiculous FC?
My Saga LMST:
Muffler original(Sport type)
Spark plug change d but still the same.
Air filter change d but still the same.
Appreciate for any help given!
Thanks.
jeheyr
834
19
5,018
Ampang Jaya
community.webshots.com
hi there,
Its depends actually, do you drive in massive traffic for your rm50/200km? or highway driving?
Or you can diagnose in proton service center.. maybe it running a bit rich..
what type of air filter you change? open pod? or stock one?
xtremeleo
3,247
464
5,183
did u change to a correct heat range, for the plugs i mean? i wud guess std lmst is using a grade 5? are the rims' size std now?
tofu_manic
1,342
91
5,148
in addition to above, mebbe tire pressure is low or heavy foot hehe
spoon civic
403
36
528
terengganu
rim size..tyre pressure...driving style..all include the factors on fc....
---------- Post added at 11:23 AM ---------- 6 hour anti-bump limit - Previous post was at 11:21 AM ----------
Hi all,
My Saga LMST:
Thanks.
maybe u should go to tune once again..maybe the tuning are not as original tuning can cause fc change....
Guys,
Greetings to all. Appreciate your input here.
Recently spun the crankshaft bearing of my 1998 1.6 Honda Civic 5 spd manual.
I suspect engine oil starvation due to plugged ports.
I am currently faced with 2 options.
The first option is to machine/turn/lathe down the crankshaft and increase the crank bearing size by 0.25mm (quarter tau). This option deprives me of the nickel hardcoating that coats the original crankshaft.
The second option is to hardcoat and rebuild the...
