Saga / Iswara Rear Brake Disc Solution
justin_vspec
619
33
3,028
Subang Jaya
darkbob said:
mitshu_saga,
what do u mean ? the engine or Disc ?
Justin_vspec,
currently i'm trying to fit my twin pots on my Original ISwara knuckle...
but i havent have had the time to go to the engineering shop and ask.
Oh alright man..Hehe once its done on your car do let us know about it!!
oldschooljam10
25
Cyberjaya
Emm,can i ask question?
im very new bout car..
this one time, i found it's hard when ure driving fast and brake using only fron disc brake, so i think of changing my rear brake from drum to disc brake, how much would it costs? can somebody explain more when changing rear brake????
justin_vspec
619
33
3,028
Subang Jaya
erm in my opinion changing your front brakes to a bigger unit (Eg-VR4 twin-pots) will have more effect compared to changing your rear drum brakes to disc brakes..Its because the brake distribution for a front wheel drive car is 70/80%-30/20%..Plus its also cheaper to change the front brakes compared to the rear..Don't shoot me yeah!! Just my 2 cents..
oldschooljam10
25
Cyberjaya
oh,it's like that? if i install that eg or vr4 disc brake,do i hv to change anything like spring,absober? what would it be the cost all around included workmanship?
Thanks anyway! :smile:
justin_vspec
619
33
3,028
Subang Jaya
erm from my knowledge from the sifus,if you use your original knuckle its plug and play..so dun have to change your absorber or spring and what not..erm i've been surveying around some halfcut shops and the price is from 380-450...i'm not sure about the labour charges..but i guess it shouldn't be much..oh yeah minumum rim size for the twin pots are 15"
mitshu_saga
420
k.l
bro....
i mean is 4g61 front disc can just plug and play ma?cos my mac say the 4g61 drive/s is bigger then the iswara,so use for long time my drive/s will keput faster then other ppl who are using ori small disc....and the gear box barring too...
so is it true?where is your location?
darkbob
152
Johor Bahry
mitshu saga,
what my friend did was, he brought the new Mirage Disc and Knuckles and the original Iswara Disc and Knuckles to the Engineering shop and had it pressed.
He REPLACED BRAND NEW Bearing on the ORIGINAL ISWARA KNUCKLES and USED THE MIRAGE HUB , DISC , AND CALLIPERS.
for the driveshaft thing. i'm not sure. i have had used mine for a long time.. but no prob.. then changed to VR4 also no prob, then changed to twin pots, also no prob.
just my 2 cents..
darkbob
152
Johor Bahry
For the twin pots,
i'm still thinking how to combine the twin pots with the original knuckles...
ARghh... HEad Ache..
mitshu_saga
420
k.l
so brother....your old VR4 front disc wanna let go ma?mirage disc smaller then the VR4 ar?if i take the mirage disc plag and play will have any problem?and how about the VR4 also?
darkbob
152
Johor Bahry
justin vspec,
the Callipers can be bolted on, i still havent had the time to go to the machine shop to ask wether they can put together my twin pot disc with my iswara knuckles.
the disc i'm not sure, its not like wira. you can just pull the disc out, the iswara version have to send to machine shop to be pulled out..
darkbob
152
Johor Bahry
mitshu_saga,
there will not be any prob for the mirage disc, just plug and pley.. hehe..
but if u have trouble with allignment or camber, reuse ur original iswara knuckles.
Mirage knuckles and Iswara knuckles are the same, so just change the hub.. thats all.. heehe.
mitshu_saga
420
k.l
bro.....if you say is the same....then why still have to change the knuckles.....cos that will cost me....wanna go pump,change barring and oil sail....so you last time wan leh...wanna let go ma?got any of your friends wanna letting that have done wan ka?where your location?meet for 'yam char'
darahhitam
2,483
5
www.cardomain.com
Disk Brake Photos
Just to share some of the newer snapshots of my E12/C51 disks combo.
Clearer photos than before, I suppose.
Will snap some pics of the E12/E33 servo/master pump too, soon.
FRONT - Ventilated E12 Disk/Caliper
REAR - Solid C51 Disk/Caliper
vestax
1,573
7
Damansara Heigh
www.fivio.com
haha darah ,
ur handbrake cable also lalu atas tralling arm wan eh ?. me also runing on that setup .
the other owners i see all use back the same route , i wonder how they streatch the cable .
darahhitam
2,483
5
www.cardomain.com
Yup,
That's the only non-protruding way it seems, clipped using the standard plastic belt-thingy.
Aiyoh, same mechanic ka? :tongue:
darahhitam
2,483
5
www.cardomain.com
"ABS" - Wangsa Maju/Jln Genting Klang.
Very near also.
