S.O.S - Satria Neo (A) 'engine failure'
Dec 4, 2013
Johor Bahru
Hi all, my Satria Neo 2006 also have engine overheat problem. Sorry I don't have a screenshot of the temperature. I was at the Causeway, engine idling, when suddenly the engine failure. The engine temp shot up to around 120 deg cel. There was also the red oil and battery icons on the display. I switch off the engine and restart the engine. I could travel a very short distance before engine failure again. Then I switch off the engine and waited a few minutes. The engine temp drop and I could drive normally again.
Does anyone have this similar problem? What could be the cause of the problem and the solutions?
Please help thanks a lot.
Rainer
Rainer
Did you check to see if you have water in your radiator?
neo83
318
9
518
Johor Bahru
Rainer
don't play2 bro..
refer at my last post..
http://www.zerotohundred.com/newforums/satria-neo-forums/437629-skim-head.html
YYC
1,833
939
Add to the above, water pump failure. But this one hard to check without dismantling.
Next year’s Formula 1 race in Singapore has been confirmed to take place on September 28, 2008. The event will be the first in Formula 1 history to take place in the evening.
Scheduled to start at 8pm, organizers have been working overtime to ensure that lighting for the race is as effective as possible. The brightness level on the street track is expected to be four times brighter than normal stadiums. However, organizers...
