rpm go crazy everytime engine get hotter...
pejalGSR
22
dear bros n sifus..
i got this problem wit my car...when first engine started the rpm is ok
but then when engine get hotter...
evrything go crazy, rpm is rattling heavily..engines feel sluggish
my ice does not sound gud..
n theres a buzzzing sound coming from my meter panel...
realli annoy me la...hahhaha
y arr...dis hapen?
issit because of my wiring?
anyone ever had the same xperience?
advice is vry2 welcome
pejalGSR
22
driving year 97 wira...
2006 change to 4g93t...
i suspect dis because of wiring..
do i need to rewiring?...if yes
how much wud it cost me?
hornydrifter
837
90
3,028
KEY EL!
Bro..the problem that u mention happen to me a year ago...small prob..but vVERY@ annoying!..i feel you bro..
tru check all the fuses to detect which one is burned (SURE CONFIRM PUNYA)...then straight check the prob..for example...ie: fuse altonator burned..then go check the altonator cap end..and so on..if u got a test pen..its even better...use it.
pejalGSR
22
ok...will try dat
thnks bros ahcmedrauff n hornydrifter
When driving on bumpy road, my car tends to have kruk kruk kruk noise from the front right suspension.
Foreman jacked up the car and shaked the wheel but found nothing's wrong.
He can't feel any freeplay on the wheel.
Anyone knows why? Would lower arm bush be the problem?
Without freeplay on wheel but still got the noise how to check?
Thanks,
