Max ATF is a full synthetic, high-performance, automatic transmission fluid. Its low co-efficient of friction and high film strength help to dramatically reduce heat and wear. Additionally, Max ATF is more oxidation stable than other transmission fluids for longer fluid life.
Automatic transmissions generate a great deal of heat and depend upon the transmission fluid for cooling and protection. More than 90 percent of all automatic transmission failures are caused by overheating; a 20°F reduction in fluid temperature can double the life of the transmission (Source: Perma Industries, Inc.). Max ATF significantly reduces heat to extend the life of your transmission.
Max ATF is fully compatible and can be mixed with other automatic transmission fluids; however, for the best results drain or flush the current oil and then fill with Max ATF.
Max ATF is recommended in vehicles requiring any of these automatic transmission fluids:
Allison C-4
Allison TES-295
Audi G-052-025-A2
BMW LA2634
BMW LT71141
Chrysler ATF+, ATF+2
Chrysler ATF+2 Type 7176
Chrysler ATF+3
Chrysler ATF+4
Ford Mercon
Ford Mercon V
GM 9986195
GM Dexron
GM Dexron-II
GM Dexron-IID
GM Dexron-IIIG and H
Honda ATF-Z1 (except in CVT’s)
Hyundai SP-II & SP-III
JWS 3309
KIA SP-II & SP-III
MAN 339F
Mercedes Benz 236.x
Mitsubishi Diamond SP-II
Mitsubishi Diamond SP-III
Nissan Matic-D
Nissan Matic-J
Nissan Matic-K
Proton SP-III
Toyota Type-T
Toyota Type T-III
Toyota Type-IV
Voith 1161521 & 1161540
Voith 55.6335.32 (G607)
Voith H55.6336.33 (G1363)
VW TL52162
ZF TE-ML 14B
ZF TE-ML 16L
ZF TE-ML 17C
Features:
Extends transmission life
Provides great wear protection
Reduces fluid temperature
Promotes smooth shifting
Ensures outstanding rust/corrosion protection
Can be mixed with other automatic transmission fluids
Proudly made in the United States.
The general rule of thumb is that automatic transmissions produce a lot of heat and greatly depend on the transmission fluid. More than 90 per cent of all automatic failures are caused by overheating. Just imagine that a 20-degree Fahrenheit reduction in fluid temperature doubles the life of the transmission! Royal Purple is the name to remember when it comes to a unique-in-many-ways automatic transmission fluid. It greatly reduces heat and thus extends the life of your transmission. Also, the Max ATF is more oxidation stable than other transmission fluids to ensure longer fluid life. On top of that, the Max ATFis compatible with other automatic transmission fluids. However, for the best result, drain or flush your current fluid and then fill with the Royal Purple Max ATF.
Why use Royal Purple?
All Royal Purple products are born to work for your vehicle while bringing you numerous benefits in the long run. The oils and lubes are rigorously tested by the RP experts and perfected on the track to enhance performance and offer superb protection for anything wrapped in metal. But what makes the RP products outperform their competitors? It’s the exclusive, proprietary Synerlec additive technology, which is the cornerstone of RP’s entire product line. Synerlec forms a tough ionic bond on metal parts in order to displace corrosive moisture. The Synerlec-enhanced products provide impressive film strength that is up to four hundred percent stronger when compared to other leading oils and lubricants.
It’s also important that Royal Purple remains on the metal surface longer than other lubricants squeezed out by heat and pressure. It improves mating surfaces by responding to increased pressure with increased viscosity until the metal peaks undergo deformation and flow into the low spots. Believe it or not, but with continuous use of Royal Purple, the metal surface becomes impressively smooth. What is more, the RP products are extremely clean, which improves equipment reliability by 300-700 percent. Although there are hundreds and thousands of synthetic motor oils to choose from, Royal Purple is really the only way to go.
Currently based in Porter, Texas, Royal Purple continues to grow in America and internationally. It was established by John Williams in 1986. Today the company focuses exclusively on creating state-of-the-art lubricants to meet and often exceed the specific demands of automotive, motorcycle, racing, and marine enthusiasts. Royal Purple's sole mission is to design high performance products that outperform other synthetic and mineral-based oils. The RP products are formulated with the manufacturer's proprietary Synerlec additive technology, which is the cornerstone of the Royal Purple entire product line.
MADE IN USA.
TEL: 012-9154001
Allison C-4
Allison TES-295
Audi G-052-025-A2
BMW LA2634
BMW LT71141
Chrysler ATF+3
Chrysler ATF+4
Ford Mercon
Ford Mercon V
GM 9986195
GM Dexron
GM Dexron-II
GM Dexron-IID
JWS 3309
KIA SP-II & SP-III
MAN 339F
Mercedes Benz 236.x
Nissan Matic-D
Nissan Matic-J
Nissan Matic-K
Proton SP-III
Toyota Type-T
Toyota Type T-III
Toyota Type-IV
VW TL52162
ZF TE-ML 14B
ZF TE-ML 16L
ZF TE-ML 17C
Features:
MADE IN USA.
TEL: 012-9154001
