Helo ,
I have recently noticed that the water level of my car reservoir tank is dropping whenever I drive .
So I top it up daily , usually will be less than a half of the tank .
I tried figuring out the problem and noticed that the radiator cap rubber has harden and shape had been out of place .
Its a 0.9kg pressure big sized cap . So it was replaced .
The water level then never dropped in the reservoir tank after the change .
I thought it was done , when then the water level of the radiator itself started dropping .
It never happened before I changed the cap / the cap is brand new .
Today with a bit of free time , I opened the cap and filled the water correctly in the radiator and reservoir then without closing the cap started up the engine .
Immediately the water drops in the radiator / once the engine starts .
Can see it by the mouth of the radiator itself .
Then top it up / just a little .
There is not a sign of leaking everywhere and revving the engine never affect the water level in the radiator and reserve tank itself too .
Then warmed up , radiator fan started to run . Water level of radiator started getting low like when I started the engine .
Top it up again and rev the engine no sign of leaking as well and engine working perfectly .
Sorry for the long description .
The water level of the rad. will lower itself when starting the engine and radiator fan operating .
Hoses all fine and not a sign of water leak can be seen .
And reservoir tank water level never dropped at all even though radiator water level dropping .
Anybody knows what's wrong ?
Hmm thanks in advance first for reading !!!
