Replace Gear Oil
Steve@
Dec 5, 2011
12
Hi, is there anyone here change gear oil for is250? Some forum mentioned gear oil has been fully sealed and better don't change it. My ride was 5 years since production but Millage only 54km. Not sure need to do any replacement or not? Hope any sifu here can advice..
robbies15
Aug 8, 2010
12
503
hey there..ed78 you had it the opposite..
gearbox oil is world standard so you dont have to change it under normal driving conditions and rear diff oil change it every 30k or every 2 years..
cheers
ed78
353
29
528
cheers
hahahhahaha..........silap.........
bro could you list the types fluids and the recomended changes?
xfuture
129
8
PJ
I've replaced my car differential oil @ last service.
TRD differential oil, gear changing alot faster. especially when dropping gears. the rubberband symptom is lesser.
Unite
Dec 1, 2010
31
sp
lexus car manual did not mention on diff oil usage.Anyone can share how many littre needed in is250?
Progressive
183
11
cheers
I just changed my ATF Fuild ..... got a shock with the colour of the fluid...macam Nescafe colour
The new fluid is Redish in colour....
After changing the ATF....the gear change upshift faster than before and cruise much smoother.
Would recomend to change ATF and the GB Filter eventhough is a maintenance free.
elephone
106
KL Cheras
may i know where you change and how much it did.
Progressive
183
11
I did it at Vision
I brought my own ATF Oil ( 4litre x 2) & drain pan gasket . ( But they no longer accept parts brought along by yourself now)
So the only charges as below
ATF Oil Filter - RM 220
Labour - RM 80
Flushing Machine Pump - RM 50
tkew
99
4
1,508
Any good workshop recomendation to do the ATF change beside vision ?
I just replace my valve cover gasket and spark plug "o" ring due to leaking at the #4 cylinder spark plug. Few weeks later, i found out that my car does not have a good idle. I saw #4 cylinder spark plug is still leaking. Can anyone help me with this problem? What should i do and what cause the problem? Thank you!
