Regarding engine stalling on auto tranny
fazidk
3,163
413
5,183
Hi guys (n gals)....what cld be d problem?engine stalled while on N in traffic jam...
Thanx
fazidk
3,163
413
5,183
In D no problem? How is the idling in P?
In D x seem to b a problem...x jerking or any signs that can cause uneasiness/butt feeling...idling while in P seems normal...x jumping up down or anything...just that this morning my wife on d way to work..stuck in traffic jam put in N then engine died..but restarting was ok (meaning one turn of key n car back to life)...
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
713
Autobox clutch gone?
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
maybe it's 1 of those day engine suka2 give shock oni @ maybe giving warning signs of upcoming headache 4 u:nurse:
fazidk
3,163
413
5,183
when engaging into N, does the rpm fluctuate? does the engine shivers/vibrate & die?
or just die off?
Seems n feels normal :( that's y la I'm confused now...but then I tested when she came back ok pulak...iiiiissssshhhhhh fening2....
---------- Post added at 01:05 PM ---------- 6 hour anti-bump limit - Previous post was at 01:04 PM ----------
Aiyooooo bro x la say like that:) hopefully nothing la...but what cld b d possible causes eh?
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
maybe injector a bit clog, that time when restart it unclog, maybe try using them cleaning additive & see wether engine sound different @ not
wifey lenovo wit tapatalk
Normally is the other way around. In N idle nicely then engage gear D die off. This is due to too low idling. But yours is in N die off...:hmmmm:
---------- Post added at 01:32 PM ---------- 6 hour anti-bump limit - Previous post was at 01:31 PM ----------
If so, then is die off in D not N....:driver: and usually for auto if clutch gone means no gear liao....:rolleyes:
---------- Post added at 01:34 PM ---------- 6 hour anti-bump limit - Previous post was at 01:32 PM ----------
ha! ha! Exactly, my wife got complain about her car one time, then when she come back and I test also nothing.....:banghead:
fazidk
3,163
413
5,183
Yeah ok will try do that n c what happens
Thanx dude
---------- Post added at 01:41 PM ---------- 6 hour anti-bump limit - Previous post was at 01:39 PM ----------
Bro vr d gearbox is 'new'...replaced it new recond unit about a yr ago...but like mentioned if clutch prob then x engage gear...hmmmmmmm fening2....
So when the car is off-load the engine dies off? Some regulator somewhere is faulty.
Out of curiousity does the aircon have a regulator somewhere? :confused::hmmmm:
How old is the car?
fazidk
3,163
413
5,183
How old is the car?
Me oso donno la got or x regulator for aircon...anyway d car is nearing 10yrs now:)
Usually for air con will have FICD to control the idle, when air con cuts in. Due to running of the compressor and heavier load, FICD will add idle speed to compensate, but then should not be the issue as issue is for gear from D to N.....:confused:
Porsche is now busy with the development of 991.2 GT3, as it has been spotted testing on the Nurburgring, undisguised.
From the images captured by GTspirit here, the GT3 now sports more squared front bumper intakes, similar to that on the Cayman GT4. The slimmer indicator units are derived from the updated 911 models, while the front apron looks largely unchanged. Featuring...
